Need Exhaust Help, designs
Discussion in 'XJ Modifications' started by jokidd82, Jun 10, 2015.
  1. jokidd82
    jokidd82 Member
    Indidnapolis, IN
    I'm really not trying to make this another i want to make an exhaust thread but i have no clue where to really start on this.
    I have a friend who is great at welding. Naturally he has a tig, a nice miller matic and a few others. I have a lincoln flux that i've realized is useless for exhaust and i'll going to get a good tank setup later. But here's what i want to do.
    I have lately noticed that the xj650 and xj550 have a lot of after market 4-1 setups. I have a D&D i got from a katana 600 and redid. Can was crushed but i was able to cut off the bad part and make it look factory. So i would really like to utilize it on my 85 FJ600. I have no exhaust except some down tubes i bought a while ago and honestly i want an exhaust whenever i first fire it.
    I'm not a fan of a 4-2-2 but my whole reasoning for the 4-1 is it looks good, sounds good, and i'm not spending 200 bucks on a 20 yr old exhaust on ebay. Id rather spend it on something i can adapt.
    My biggest problem right now is the room under the pan. I have the oil filter in the center i have to go around but then on the left side almost make a 90 to get the other side.
    Well anyway i noticed that a lot of 650 and 550's have a similar design. I can weld a pipe in with a mandrel cut no problem. But if they have a header set up that flows over to the peg i can go from there easy.
    Does anybody know the diamater of these pipes from the head or at least a picture of a factory or 4-1 under the oil pan. I'm curious and google isn't helping me with its vomiting of every xj out there.
  3. jokidd82
    jokidd82 Member
    Indidnapolis, IN
    thanks k-moe but i would really like to see a close up of what it looks like under the bike assembled. As long as the 4-1 makes the turn before the swing arm i don't see a problem. I also want to keep the center stand if at all possible
  4. jokidd82
    jokidd82 Member
    Indidnapolis, IN
  5. madbones
    madbones New Member
    australia
    Ive got a 4 into 1 on my xj600. Dont know if the pictures might help but it does run down the R/H side opposite side to the kick stand.
    Let me know, im happy to post some shots.
  6. jokidd82
    jokidd82 Member
    Indidnapolis, IN
    That would be great if you could. I really need the underside pics more. I took a 3 week break on it sinceit was starting to piss me off.
  7. Toomanybikes
    Tsawwassen bc
    Just make sure you clear the oil drain plug, would be big pain to pull pipe for oil change
