Need fork dampener part
Discussion in 'For Sale, Trade/Swap, Wanted' started by JimS53, Apr 4, 2023.
  1. JimS53
    JimS53 New Member
    Jacksonville, FL
    I started the rebuild of the forks on my 1981 Yamaha Seca 750 and had a few surprises. Looks like someone upgraded fork springs and used metal spacers unfortunately they left out a few parts. I am looking for the aluminum part to the dampener end. Look at picture attached. I can order the washers that are missing but not sure what this part is called. Let me know if someone has one for sell or knows the name of the part.
  2. Fuller56
    Fuller56 Well-Known Member
    @JimS53 looking at Partzilla's fiche of your bike's fork that part appears to be:
    OIL-LOCK VALVE ASSEMBLY
    5G2-W2311-00-00
    the bad news is that they also say it is "unavailable". Check with Len Chacal at XJ4EVER, his link is in the right upper corner of this page. Good luck.
  3. JimS53
    JimS53 New Member
    Jacksonville, FL
    Thank you. I have sourced one.
  4. Kyruss
    Kyruss New Member
    West Michigan
    Have you a source for the tiny “shim” sized washers? I have the rest of the oil lock assembly, but apparently this one’s missing the tiny flat washer and the wave washer that’s part of the relief valve thingy between the lock and the tapered washer.
    I’ve been searching for days, and all I can see is the whole lock assembly from eBay for $50 or more. I’d hate to spend that much for two tiny paper thin washers.
  5. chacal
    We do have both the flat and wave washer available:
    HCP19354 Aftermarket inner fork tube oil lock valve SPRING WASHER, fits either side. Used on all 1981-83 XJ750 Seca and XJ750 Euro models with anti-dive forking system. Use 1 per tube, each:
    HCP19353 Aftermarket inner fork tube oil lock valve FLAT WASHER, fits either side. Used on all 1981-83 XJ750 Seca and XJ750 Euro models with anti-dive forking system. Use 1 per tube, each:
    You can send us an e-mail at: info@xj4ever.com
    or use the "Conversation" feature on this website to send us your request and we'll reply with pricing, shipping options and costs, etc.
