Need Help, carb question
Discussion in 'XJ Technical Chat' started by vanndrage, Sep 19, 2011.
  1. vanndrage
    vanndrage New Member
    i just picked up an XJ750 and it is missing a carburetor. i would appreciate if someone can help me identify what i need to purchase. i will admit i have no knowledge when it comes to carburetors so i appreciate any help. i have attached a couple pictures.
  2. iwingameover
    iwingameover Active Member
    you'd need a complete carb. Maybe easier to source a whole rack than a single carb. PM member chacal (xj4ever) he'll have what you need.
  3. MiGhost
    MiGhost Well-Known Member
    The carb body that is missing is the #1 carb. 750 Maxim, or Seca will work as they are the same. 650 carbs will work, but will have to be rejetted to work on the 750.
    There are several places to locate what you need. Your best bet is to get a complete rack and rebuild it. Untold damage from PO with that rack as is.
    Ghost
  4. KrS14
    KrS14 Active Member
    St Marys, Ontario
    You're missing a choke plunger lifter as well. Better to source a new(used) rack if you can i'd say!
  5. Mr.Etobicoke
    Mr.Etobicoke Member
    Toronto, Canada
    And the fuel tube that goes between carb 1 and carb 2.
    Kenneth
  6. bigfitz52
    Just buy another rack off eBay, and rebuild that. There are at least a couple from 750s up right now.
    Use what you have for a parts rack and don't break anything in the #1 carb on your "new" rack.
    That's honestly the cheapest route. Then at least you have a solid starting point.
  7. vanndrage
    thanks for all the quick replies.
