Need help solving this problem
Discussion in 'XJ Technical Chat' started by MaximXJ, Sep 25, 2008.
  1. MaximXJ
    MaximXJ Member
    West central Wisconsin
    Hello everyone
    Cylinders 1&4 are not firing
    First off, I've used the "search" feature before creating this thread. I've found a few related threads but nothing exactly related to my problem.
    The best I can describe the problem is just a lack of power, it feels like I'm riding a moped now compared to what my XJ650 used to be like.
    I rode the bike one evening and it ran excellent, just how it has been all summer.
    Parked the bike that evening (outside), stormed/rained pretty hard all day the next day, then the following day after everything dried up I started the bike and it started just fine but was running really rough and took awhile for the engine to rev.
    Tried to ride the bike even with it running strange, and the bike has no power!
    What I've done so far:
    Replaced spark plugs
    Put the petcock into the "Prime" position
    Checked air filter
    Still runs poor.
    Can anyone help me? The season is coming to an end for us in Wisconsin and I've gotta ride as much as I can before the winter sets in.
    The bike is a 1981 Maxim 650
    Thank you,
    Paul-MaximXJ
  2. mikeg
    mikeg Member
    Milton, Vermont
    I'd try replacing the gas. Maybe you got some water in the tank.
    mikeg
  3. MaximXJ
    MaximXJ Member
    I should have added that I topped off the tank yesterday with new gas (3/4 of a tank worth)
  4. KrS14
    KrS14 Active Member
    St Marys, Ontario
    coils got wet possibly?
    check your spark
  5. MaximXJ
    MaximXJ Member
    Checked spark already and all plugs spark good
  6. bigfitz52
    Water is heavier than gasoline. Topping off the tank won't do anything if there are "blobs" of water floating around in the BOTTOM of the tank, getting sucked into the carbs along with (some) gas. I would put the bike on the sidestand and then leave it TOTALLY STILL for an hour or so. Then disconnect the fuel line from the petcock, hook up a bit of appropriately-sized hose, and put the petcock on "PRI" and drain out a quart or two of gas. You'll probably get the lion's share of the water. Follow it up with some Sea Foam to "dry" the remaining water and you should be good. (Assuming it's not simply a wet wiring problem.) If it is water in the fuel, you might want to consider rebuilding your gas cap.
  7. bill
    bill Active Member
    Raleigh, NC
    Sure sounds like something is wet still or has corroded. Try checking all the electrical connections - starting with your coils, the pickups, the TCI, Battery etc...
    Make sure they are dry and clean.
  8. MaximXJ
    MaximXJ Member
    Excellent idea. I have a feeling this is my problem.
  9. MaximXJ
    MaximXJ Member
    I will be going through this tonight as well, hopefully with the combination of getting rid of the water if the gas (if that is my problem) and checking the electrical components I should have a properly running bike by the end of the night.
  10. NursePadawan
    NursePadawan Member
    Lansing, MI
    If you're going to be parking your bike out doors, you may want to invest in a bike cover. Just a thought.
  11. MaximXJ
    MaximXJ Member
    Ok well I don't think it's water in the gas
    I took the bike for a ride and checked the exhaust for heat
    The outside two are hot/warm
    The inside two are really hot!
    I have spark on all 4.
  12. wizard
    park the bike in full sun all day.
  13. MaximXJ
    MaximXJ Member
    It has been for two days :/
  14. flash1259
    flash1259 Member
    W.R. Wisconsin
    Have the float bowls been emptied ?
  15. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Try This,
    Pull your plug wires off and blow out the caps & boots with compressed air. Take your plugs out and look to see if there are carbon tracks down the insulators to the metal. Put alittle dielectric grease on your plug boots pop the plugs and wires back on and see what happens when you fire it up. Moisture can stay in your boots for along time and may be shorting your plugs out. Maybe that will help. Good Luck
  16. bigfitz52
    are there still puddles around the inner (2 &3) spark plugs? I would also try draining the carbs, maybe whatever water WAS in the tank got sucked into the carbs already, and it will do the same thing, lay in the bottom...
  17. sagebrush
    sagebrush Member
    IF WATER RAN DOWN INTO YOUR AIR FILTERS AND SOAKED THEM, THEY MAY NOT DRY OUT UNDER THE SHADE OF THE SEAT.... ???/
  18. bill
    bill Active Member
    Raleigh, NC
    I'm with Fitz - check the bowls
  19. ItsMikey
    ItsMikey Member
    Warren, MI
    If you drain some fuel from the tank into a glass jar, and let it sit for a while, any water that is there should settle out and you should be able to see it. You can also start the bike at night in total darkness and look for sparking around the coils and plug wires. Should you see any, you can try using starting fluid to evaporate the moisture with the bike off, restart the bike, and re-test. Make sure that all of the ether evaporates before restarting, or you will have another issue to address!! That should help you determine if the storm was the source of the problem or merely coincidental to the start of some other problem.
    Hope that helps, Mike
  20. MaximXJ
    MaximXJ Member
    Well I think it's not a fuel issue.
    I'm thinking I have a problem with the TCI unit
    "Yeah, if only #1 isn't firing, it isn't a TCI or Coil issue. Both #1 and #4 fire at the same time from the same TCI signal so one cannot work without the other, unless there is a wire issue. What you should do is switch the signal wires (primary if you will) and also switch the plug wires (1&4 to 2&3 and visa versa). The dead cylinder should move to #2 then if it is a wire issue. I would also try replacing that spark plug also, it isn't unheard of for a brank spankin' new plug to be bad. If the dead hole does switch to #2, unscrew the cap, trim back the last 1/8" of plug wire or so and screw in the cap onto new wire. Make sure that the copper wire is at the end of the insulation and not playing hide-and-seek. While you have the cap off, check the resistance through the cap, I can't remember the spec though, but they are resistive caps."
    ^From another thread I was reading, since 1&4 are dependent on one another with the TCI unit, I'm thinking this is my best guess
