Need help with a Voltage Reg pinout
Discussion in 'Other Motorcycles' started by Timbox, Jul 19, 2025.
  1. Timbox
    Timbox Well-Known Member
    Been looking online for a pinout of this voltage reg, can find one. It is a Honda SH586B-12
    The wiring harness got all messed up and the wires no longer are attached to the OEM places. I know the stator White with two red dots is one of the bottom pins, the other stator pin is Gray with two red dots. I need to know the three pin row. One seems to be marked with a "B" top left as it faces you. Just need to know so I don't fry anything.
    [​IMG]Reg by Tim Brown, on Flickr
  2. Timbox
    I thought for sure I would have a pic with the wires to the locations I needed. I will keep trying to figure this bad boy out.
  3. jayrodoh
    jayrodoh YimYam
    Cleveland
    Found this online, the stator and B terminals match up with your description but I can't guarantee anything! Good luck!
    Timbox and Rooster53 like this.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    I posted the six pin version, the five does not have the warning light terminal. Checked a few others and they have the same pinout.
  5. Timbox
    @jayrodoh, thanks so much! I just got the coil put in the "tail Wagon" today, that old Honda GX390 cc fired right up. Only a little 13 Hp motor in a 2007 side by side. Still hate to see things go to the junkyard for no good reason. It does look to be what I have and need.
