Need help with mystery tank
Discussion in 'XJ Technical Chat' started by NF89, Oct 10, 2019.
  1. NF89
    NF89 New Member
    Centralia IL
    Beginner here. Anyone know what fluid goes here?
    Thank you for your time,
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Looks like the coolant tank.
  3. NF89
    NF89 New Member
    Centralia IL
    Does it matter what coolant I use?
  4. FJ111200
    I wouldn't think so but i'd try to either use the same as what's already in it or get some fresh and don't mix the two.
    I use a HOAT coolant/antifreeze in my Tiger 800.
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    Drain the system and re-fill. If you don't know what's in there you can risk the whole mucky mess turning to sludge/gel. Been there, done that. Colour is no guide by the way.
    Rooster53 likes this.
  6. NF89
    NF89 New Member
    Centralia IL
    Thank you guys. I was fairly certain I knew it was antifreeze, but wanted to be sure. I drained and refilled about a year and a half ago, but then it went down right after and I hadn’t driven it yet. Finally found a shop to fix it and just got it back (for winter) and then my truck died. I had to get going with my day and noticed that the tank was empty (not sure If they drained most of it or what, the straw was even out). I couldn’t remember where the tank was and was in a panic. I didn’t respond, but seen both your messages and I appreciate the advice. Ease of mind makes for a much better day. I’m sure I’ll be posting here a lot since I’m not very good with mechanics. Thank you guys again.
