Need help with power loss issue
Discussion in 'XJ Technical Chat' started by Xj900rk-nightrider, Aug 16, 2015.
  1. Xj900rk-nightrider
    Xj900rk-nightrider New Member
    Canada
    1983 yamaha seca xj 900 rk
    Bike was ridden in the rain yesterday and for some reason doesnt feel like its got that top end power band anymore
    Back fires and revs out before putting out
    Change plugs tests plug caps for resistance
    Volt meter tested coils
    Both at 12.5
    Anything else i could try
  2. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Have a look at your carbs.
    Pay close attention to the cleanliness of the fuel jets and emulsion tubes. Also, verify your fuel levels in the bowls.
    I'm betting you are running lean on the top end.
  3. Xj900rk-nightrider
    Canada
    Ive also had the carbs and valves set recently too
    So im just stuck but it back fires or over combusts so im not sure whats going in
    This is still the conclussion even tho i rode in the in rain and ot acted up than went away, but today has come back?
    More like you have cracked plug wires, caps, or coils. Start her up in the dark and see if there is a lightshow.
    rocs82650 likes this.
  5. Xj900rk-nightrider
    Canada
    Hey thanks man i took the caps off and test them the resistance was equal all around i test the coils seemed good still didnt run fine, i left for a few hours came back started it up n it was mint,
    If i start it uo in the dark and everything seems fine, where can i look back to if j run into the problem again
  6. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Mist the plugs and wires with a trigger sprayer lightly in the dark. You will see a lighting show more than likely. Also pull your gas tank and see if the coils have cracks in the plastic housings. I just upgraded one of my bikes for this very reason to Dyna Coils from xj4ever.
