Need needle valve thread size.
Discussion in 'XJ Technical Chat' started by Robert24b, Oct 3, 2023.
  1. Robert24b
    Robert24b New Member
    Colorado
    Just got a donor bike (xj650 with hsc32 carbs) and the carb has 2 needle valves that were cranked down by a gorilla.
    What size tap do I need to chase those threads? I have since extracted the stripped needles but the threads need help.
    Thanks in advance.
    Edit: this is for the needle adjustment screw next to the choke plunger. Thanks.
  2. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    The pilot screw thread is M6 x .5
    This was as measured on the HSC32 from my 750. I assume they aren't different on the 650....
  3. Robert24b
    Colorado
    You're a life saver! Thanks
