Need the help of my fellow XJ'ers.
Discussion in 'XJ Technical Chat' started by Lantzalott, Aug 21, 2013.
  1. Lantzalott
    Lantzalott New Member
    Cathlamet,WA
    Hey Gentleman. You may remember my post about coil not firing on 2/3. I bought new coils but that didn't solve the issue. So, I turned to you for help, through which I was able to narrow it down to the TCI box. I took it to a radio repair shop today and for $50.00 he went through it and replaced all of the burned outs and a few that he thought looked their age. Got home, slapped it on and it didn't run quite right. Now the 1/2 are firing but 3/4 aren't. So I waited till darkness, pulled the plug wires on 3/4 and behold, there was spark! I am certain that 1/2 have spark because the exhaust is hot one those two. So I am thinking that the next step is fuel delivery to 3/4 carbs. Am I right? And any other suggestions are always appreciated. Ride Free My Brothers and Thank You!!
  2. wizard
    Don't know what the guy replaced, but he could have screwed the timing..
  3. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    yea... check your basics... fuel + spark
  4. CapnRedbeard
    CapnRedbeard Member
    London England
    I thought one coil fed cylinders 1/4 and other coil 2/3..? So if 1 & 2 are firing you should also see a spark at 3/4 !
    Sounds possible fuel related, so you may need to pull carbs and do the Church of Clean - see Chacals writeup.
  5. Lantzalott
    Cathlamet,WA
    WOOT! WOOT! "SUZIE" IS ALIVE AND WELL!!
    I had air and spark so I re-routed the fuel lines and found a kink in 2 places. Straightened them out and I am one happy man! So I guess the guy at the radio repair shop actually did fix the TCI!! HAPPY RIDIN TO YOU ALL!!
    Thank you for all of your help.
  6. CapnRedbeard
    CapnRedbeard Member
    London England
    Definitely fuel related then! :)
