Needle Valve recommendation
Discussion in 'XJ Technical Chat' started by RusteeGold, Jun 4, 2015.
  1. RusteeGold
    RusteeGold Active Member
    Southern California (RSM)
    Hi
    I'm cleaning my carbs on my 1982 Seca 750 and I think that at least one of the needle valves needs to be replaced because it seems to not be sealing when its seated.. Since I already have the carbs torn down I figure I might as well replace the needle valve in all four.
    So what's my best option to acquire the needle valves I need?
    Steve
  2. mlew
    mlew Well-Known Member
    Apex, NC
    PM Chacal at XJforever , he has the parts you need.
  3. hogfiddles
  4. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Yes.
    Click on the icon in the upper right hand corner of this web page. Then click on the tiny icon of XJ4ever that is next to the list of subjects - you then select "Start a Conversation" / PM (private message).
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    Beware of the cheap sets online, they often leak and tolerances are not tight resulting in variations. Went through he'll on my Kaw by buying the "ebay kit".
    The ones Chacal sells are spot on.
