neutral indicator lamp
Discussion in 'XJ Technical Chat' started by fixincars, Apr 24, 2016.
  1. fixincars
    fixincars New Member
    St. Louis Mo. USA
    lit when clutch lever is pulled in and in neutral of course. i just put a 90$ omron relay from yamaha and also replaced the coil pulse generator as the grey side had no resistance. i did replace the entire assembly wires and all. Thanks to the ultimate guide to relays here @ xj forever. it was a used pulse generator but the wires were in good shape & both pulse coils had 600 ohms (like 646 each). everything works properly if the lamp is suppose to be on when the clutch lever is pulled in. But i doubt that , could my clutch lever switch at the lever be wrong for the bike possibly? it looks correct but i have not traced the wires.
    Also the lamp stayed on always upon replacement until i adjusted the clutch a little tighter at the lever. now the lamp is only on when the lever is pulled or when in neutral.
    fuse block is replaced with spade connectors & newer one inch type fuses. any advice?
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    The lamp should stay lit as long as the bike is in neutral.
    Gary H.
