Neutral light from starter diagnosis - 2 problems
Discussion in 'XJ Technical Chat' started by PSteele, Jun 14, 2009.
  1. PSteele
    PSteele Member
    Nova Scotia, Canada
    Here is an interesting question for all the XJ heavies. I have been trying to trace why the starter won't roll on demand. This is an ongoing issue since I got the bike 3 years ago. After an afternoon with the service manual and a meter, I think it comes down to the starter relay next to the battery. However, since one is not readily available, I put her back together and can live with the occasional bump start. One of the Yamaha Old Hands at the 2009 Bike Blessing said "typical Yamaha starters", but I find this hard to believe.
    This is not a battery issue - I crammed a 20A gel battery in there and there is more power than needed. This issue persists with a large car battery and cables, so it seems to not be connections or battery. Any random time the starter button is hit, the starter simply won't turn. It is about a 50/50 proposition today, getting worse by the week. When it does turn, the engine fires up immediately. One suggestion over the winter was to place an all-weather switch between the battery and starter to make a short direct path, but this didn't appear to be the best option.
    However since putting it back together, when the clutch is pulled, the neutral light comes on. Sure this is not a big safety issue, but it is certainly distracting. Did I fry a relay or something as I was testing?
    Any help on either issue would be appreciated.
  2. SQLGuy
    SQLGuy Well-Known Member
    The "starter relay" next to the battery is called the starter solenoid. Chacal has them, so they ARE available. You don't mention which bike you have, but the ones he has fit all XJ's. People have also had good luck retrofitting lawnmower solenoids.
    Testing the solenoid is as follows:
    1. Try shorting the heavy terminals of the solenoid with a screwdriver you don't care too much about. If this reliably runs the starter, then the starter is OK. If it doesn't, then look into new starter brushes, cleaning the starter out, etc.
    2. If the starter was OK from step 1, try removing both smaller terminals from the solenoid and jumpering +12V and ground to them. If this reliably runs the starter, then then solenoid is OK, and the problem's somewhere in your safety circuitry, starter switch, or ignition switch.
  3. PSteele
    PSteele Member
    Nova Scotia, Canada
    SQL, I truly appreciate the advice, which will get a trial this weekend. The manuals call this a relay even though it reminded me of a Ford solenoid that sits on a fender well instead of on the starter like a GM. Should have figured that the diagnosis process would be as simple.
    Anyone have any ideas why the Neutral light comes on when the clutch lever is pulled?
  4. MiCarl
    Could be wired wrong, could be a bad diode. Which bike?
  5. PSteele
    PSteele Member
    Nova Scotia, Canada
    The bike is my avatar - xj650j - and the issue started after I went through the system with a meter checking relays, etc. I have not changed any parts or changed any wiring. Weird.
  6. tennsouthernbelle
    tennsouthernbelle Member
    Morristown, TN
    I too have had starting issues, from the starter just needing brushes (it is a 28 year old starter) to a bad connection from my starter button to the fuse box that was installed by the PO. Is there a stock fuse box in it? If not maybe chase down the connections when a new box was put in.
  7. PSteele
    PSteele Member
    Nova Scotia, Canada
    Nice try tennsouthernbelle, but the fuses were history long ago and the starter button tests out fine.
  8. bill
    bill Active Member
    Raleigh, NC
    Sounds like a classic case of the solenoid going bad - mine did the same thing. Paul's test will tell you for sure.
    neutral light has to be the diode block as Carl said or a short - clutch switch and neutral switch do have the diode block in common.
  9. PSteele
    PSteele Member
    Nova Scotia, Canada
    Appreciate all the advice fellows. I shall try these tests this weekend. Just to be clear, "jumpering the small terminals" of the solenoid means what exactly? Last thing i need to do is fry something else. Electricals usually mystify me, so specifics are appreciated!
  10. RickCoMatic
    Typical Yamaha Starter.
    Could be.
    The Yamaha Starter Brushes are BIG.
    They wear-down and make a lot of dust.
    The dust gathers all-over the Starter's Electrical end. Once enough CARBON DUST collects in the Armature ... the Starter gets "Intermittent"
    Not long after ... it quits.
    Remove the Starter.
    Undo the two Long Screws and pull the Electrical End out a little bit.
    Look in.
    If there's black carbon dust all over the place ... douche it out.
    Use a whole Bottle of Isopropyl Alcohol.
    Trigger-pull Squirt Bottle.
    Spray the whole Electrical end, Armature, Brushes, Casting until whats coming out is as clean as what's getting sprayed on.
  11. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I, too, had a similar problem. Thought I had it nailed down to a bad solenoid. Replaced it and all was well... for a week. And then nothing. Hit the starter button and nothing. Arggh!!! Right?
    So, I tore my tank off and looked at the starter safety relay. After some testing, prodding, and poking, it turned out to be a loose connection at the relay's connecter. I could hold the starter button in and twist the starter safety relay pigtail and the bike would start. I removed the relay and bent the metal tangs out slightly so they would make good connections in the pigtail again. I haven't had a problem since.
  12. SQLGuy
    It means directly connecting, with two lengths of wire, one to ground, and the other to +12V. Connect one side first, then touch the other side to its terminal.
  13. PSteele
    PSteele Member
    Nova Scotia, Canada
    Again, thank you all. Rick, this clean out was done with the starter last year, although it could be done again when I replace the generator gasket as it is not much more work. Brushes were OK but worn, so maybe there is another weak spot. Don, I tested the relay under the seat and it does check to spec and seems to fit OK. I will give the wiggle test a try. Promise to keep my patience handy and dynamite in a far away place.
  14. gitbox
    gitbox Member
    Psteele, regarding your neutral light question:
    Here's a diagram of the starter circuit on an XJ650J.
    If the neutral light comes on when the clutch lever is pulled, I would say you have a shorted diode in your diode pack - the one that goes between the clutch switch and the neutral switch on the diagram.
    The switches act like an "OR" gate, i.e. either the clutch switch OR the neutral switch will allow the safety relay to engage thus allowing the starter button to energize the starter relay. The diode is there to prevent exactly what you describe - the clutch switch illuminating the neutral lamp.
    Incidentally, the diode right above that one is used as a lamp test to illuminate the oil indicator light when the starter button is pressed. Either the starter button OR the oil level switch will light the oil indicator. The diode there prevents the oil level switch from energizing the starter which wouldn't be a good thing.
    Geez, I hope I don't sound too technical or condescending.
  15. PSteele
    PSteele Member
    Nova Scotia, Canada
    Technical or condescending - geez gitbox, hardly! Great information, just hope I can get it fixed properly. Starting issue #1, light after. Again, thanks to all you XJ-perts. My weekend sounds busy.
  16. PSteele
    PSteele Member
    Nova Scotia, Canada
    OK Guys, I tried the suggestions above. Took the time to open, clean and close as many connections as could be reached. Wiggled all the pigtails while holding starter button. Jumped the big terminals with a screwdriver and this ran the starter every time. Could not disconnect the smaller ones as they seem to be factory soldered.
    The solenoid seems to click better, but now while the bike starts reliably on a bump, will not turn the starter at all on its own.
    Vewy, vewy fwustwating.
  17. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Just for the sake of clarification, were you able to disconnect the starter solenoid's pigtail, the one with the red and blue wires?
  18. PSteele
    PSteele Member
    Nova Scotia, Canada
    Yes I was and it never crossed my mind to jumper that part that way. Is that what you're driving at Don? Sounds like a good way to do it, but with my fear of frying something, I await your reply.
    While waiting, I checked out your How To on the starter circuit - looks like I need to hang around this site more often, as I did not know it was there. GREAT how-to, so let me deal with that and get back to this topic in the next few hours.
    Thanks for the superb how-to! Great photos and information.
  19. RickCoMatic
    We're a Full Service Agency.
    Doctors who specialize in all areas.
    You should have SPUN the Starter when it was off the Bike.
    A Battery Charger.
    Negative to the Case.
    HOT Lead touch the Pigtail Post.
    See of hitting the Motor with 12 Volts makes it go.
  20. PSteele
    PSteele Member
    Nova Scotia, Canada
    Well, after getting to the bike today, here is what I have found. First, the starter spins every time using the screwdriver between the posts trick. Jumping the pigtail results in a clunk in the solenoid and that's all. So, it sounds like I need a solenoid, correct?
