neutral light
Discussion in 'XJ Technical Chat' started by ant797, Apr 13, 2016.
  1. ant797
    ant797 Member
    western australia
    i need to get the neutral light working on dash i was over confident i found the neutral s switch and figured bit of a clean should be right it diddnt work grounding the wire diddnt work either my question is if someone has bipassed this wich i think they have cause it cranks in any gear would this disable the light if so where do they bipass it
    did you check for a burnt out bulb?
    is your clutch safety switch installed and working? if you bypass the clutch safety switch by jumping it bike will start in gear on side stand
    is your sidestand relay inplace and working?
    is the black white wire on your tci connected
    what bike?
    edit
    removed light thought
    sky blue wire runs up frame with the pickup coil harness
  3. k-moe
    If grounding the wire didn't work then the problem is definitely upstream of the switch.
    The light would be on and you would not be able to get the enigne to spin in gear with the clutch out if it were not bypassed.
    Remove the seat, and the fuel tank. Start tracing that sky-blue wire back to the safety relay (and check that the realy is there and hasn't been bypassed).
  4. ant797
    ant797 Member
    western australia
    i checked that the relay is there it is . i got a new bulb tested and works elsewhere . i traced the wires coming from the bulb to a flat square connector theres 3 of them including a brown one but on the other side where brown one goes to the pin seat is empty.. side stand has wires leading to a switch installed clutch has wiring coming from it ...the tci unit i havnt checked
  5. XJ550H
    does the relay click when you turn on the key?
    there should be 3 wires there a black ground wire, a brown power 12 volt wire, and the sky blue wire
    the black wire is for the turn signal lights
    brown is power for neutral light and shared with tach and front brake switch
    any 12 volt source will work to make light work you could test it with a wire with fuse from battery or run it back to the signal fuse thats where it comes from any ways
  6. ant797
    ant797 Member
    western australia
    thats great to know thanks
  7. ant797
    ant797 Member
    western australia
    still not coming on must be that the neutral safety switch is rooted makes sense proberly y they bipassed it maybe not come to think of it i dont hear that click maybe the kickstand switch was rooted and they bipassed the relay
  8. XJ550H
    did you ground out the blue wire when voltage was applied to brown wire?
    sky blue wire has a bullet connection under the seat in front of fender . the blue wire is part of the cable from pickup coils to tci unit the right connector
  9. ant797
    ant797 Member
    western australia
    i found that bullet connection under the seat basicly the sky blue wire connects to a difernt coulor wire from the tci ...i connected a brown wire to the brown wire coming from bulb to to a brown wire screwed into the back of the tach i diddnt ground the blue wire ...i got a neutral switch on order i will wait for that i hate fidling with that thing once i get the new one i can install it and eliminate it as a problem
  10. ant797
    ant797 Member
    western australia
    so basicly the po has potentialy grounded out the blue wire somewhere and disconnected power to the bulb....although when i had a fiddle with the blue wire running to the tci under the seat it wouldnt crank perhaps the bullet needs a clean and formin a ground there doesnt explain the light not coming on though
  11. XJ550H
    blue wire does not connect to the tci , there is a black white wire that connects to the tci the skyblue wire is probally under the tray accessable near fender under frame behind air box
  12. ant797
    ant797 Member
    western australia
    there is a black white wire empty at tci and there is darker blue wire coming from the tci connecting to sky blue wire running up the harness
  13. k-moe
    The neutral switches rarely fail, but they do get gummed up with sludge. It might just need a good cleaning, and you won't know that it's faulty until you can get the neutral light to come on by grounding the sky-blue wire, but not by putting the trans in neutral with the switch hooked up.
    Also, we need to clear up the wiring color issue. Not all XJs use the exact same colors for the same circuits. Which year and model are we troubleshooting?
  14. ant797
    ant797 Member
    western australia
    ok i connected the brown wire to the tach power got off my lazy ass and grounded the wire end at nsw the light came on ..this would mean if the nsw plunger was stuck in it would light all the time because it doesnt i amagine the plunger is warn down providing the plunger goes in not out not in on neutral
  15. k-moe
    Run Seafoam or some other crankcase solvent to see if the switch frees up. Getting the switch out while the engine is in the frame is a huge ordeal.
  16. ant797
    ant797 Member
    western australia
    yeah i figured that i couldnt get a size 13 socket in there i tried a size 12 seems to be too small or wrong angal ...nevermind thanks heaps i got it working must of been a combo of no power and being gummed up i gave it a bash with a screwdiver and it works now although 1 out of 3 or 5 times it doent come on but once i get some oil in there it should work through
  17. k-moe
    Good deal. You can't get any socket in there without cutting it down to fit.
  18. ant797
    ant797 Member
    western australia
    thanks k-moe and xj550 its amazing you guys remember so much i forget things nearly as soon as i finished them
  19. 81550Seca
    81550Seca Member
    Yakima, WA
    What is the sky blue wire for?
  20. XJ550H
    sky blue wire goes from neutral light to neutral switch it is ground for the bulb. Sky blue also goes to diode block from neutral switch supplying a ground for starter safety relay
    relay in lower left is starter safety relay.
