New Brake Line Issue
Discussion in 'XJ Technical Chat' started by machelis, Mar 28, 2013.
  1. machelis
    machelis New Member
    An island in Eastern Canada
    I got some new stainless braided brake lines which fit and look awesome, except for where the lower hoses connect to the dual banjo bolt. It seems the ends of the lines are wider than stock so the dual banjo doesn't fit properly. Are there different lengths of these bolts? or should I change my splitter?
    Thanks.
  2. bkerby
    bkerby Member
    MO
    Should be able to purchase a new bolt from supplier that is correct in length and spacing. My new setup was off a little bit where holes in bolt matched up to lines but was close enough to work properly.
