New coils and now it backfires and won't start it kind of starts but the second you give it any thou
Discussion in 'XJ Technical Chat' started by Reed whitehead, May 23, 2020.
  1. Reed whitehead
    Reed whitehead Member Premium Member
    It seems like it wants to start and it idle for a second and a half the second you put any gas on it it dies
  2. SQLGuy
    SQLGuy Well-Known Member
    What was it like before you replaced the coils?
  3. XJ550H
    untill it warms up a little more more throttle is not the answer. more choke
  4. XJ550H
    what coils did you install
  5. Reed whitehead
    It ran but only on two cylinder
  6. Reed whitehead
    It won't idle
  7. Reed whitehead
    I'm not sure what kind they are I'll have to check but they ohm perfectly
  8. Timbox
    Reed,
    Pls give us a little more detail of what the issue/issues are. I get that you are having spark and running issues, but was the bike ever running? Give us a background at what the bike has been doing too. Is it new to you? Was at a barn find? Were the carbs and gas tank cleaned? Or is this something that just happened and you decided to change out the coils just because?
    Thanks and looking forward to some background info.
  9. SQLGuy
    If it runs at all, the coils and ignition are probably OK. I think the problem is fuel related. If you spray carb cleaner into the airbox, or put some propane in there (from an unlit torch), does it run better for a few more seconds? If it does, that would be more confirmation that spark is OK and fuel is not. My guess is that you need to do a full carb overhaul.
