New fuse block question.
Discussion in 'XJ Technical Chat' started by Xjrider92117, Sep 2, 2014.
  1. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    I bought a new fuse block and I was wondering if I could solder the wires to the fuse block and then put some heat shrink over it? Or should I just get the crimp style clips to attack to the fuse block?
    Thanks.
  2. Polock
    no, you have to put the heat shrink on before you solder it :)
  3. k-moe
    While you could solder directly to the terminals on teh fuse block, crimped connections are easier, faster, and more resistant to breakage from vibration (unless you are proficient at soldering). Crimped connectors also make it easy to swap out the fues block if it should ever become damaged.
