New start switch wiring XJ550
Discussion in 'XJ Technical Chat' started by Lars Antonsen, Apr 21, 2022.
  1. Lars Antonsen
    Lars Antonsen New Member
    Denmark
    Hi
    Just bought an XJ550 1983.
    But i have an electrical challenge..
    The previous owner dismounted the original handlebar switches, so he could replace them with new ones, non-original.
    But i can’t figure out to connect them to the mainwiring on the bike..
    I really really hope there is soneone who can guide me in the right direction
    Thank’s in advance
    Kind regards
    Lars from Denmark
    the connector for the throttle side is located aside of the right ignition coil.
    it is a black connector . has 2 red wires maybe stripped white this is the kill/run switch
    also a blue striped wire which runs from solinoid to starter button
    there is no black wire (ground) in the harness wire connector as the metal shell grounds to handle bars . the ignition coil mounting bolts make a good ground point
    Lars Antonsen likes this.
  3. XJ550H
    with your new switch the kill wire and power to kill wire should connect to red wires
    power of start would go to blue wire and you want to test through the start wire as this would be ground in the starter button. . just want to make sure of which is ground
  4. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    ok, i'll have a go for you, though i am not familliar with the 550, but going from the pictures you have supplied,-----------
    so we are looking at the wires for the R.H. handlebar switch only ,for now
    so both Red /White wires are the kill switch Loop
    so one of the Red/White wires goes to the blue connector of the new switch
    the other Red/White wire goes to the yellow connector of the new switch
    the light blue wire (in the harness in your hand) goes to the starter switch, Black/White wire
    the Orange wire from the new handlebar switch ,goes to earth, to ground out the starter circuit, i think on the original switch the ground was through the handlebars, but you can just ground the orange wire anywhere convenient.
    the black wire in the new switch, it states, is for a gear indicator, which your 550 wont have.
    the other wires in the harness in your hand should be --------
    Red /yellow is feed to main light switch
    Dark Blue is feed out of main light switch to High/Low switch
    which is now, on the new L/H switch
    cant find a Blue/Black wire on your diagram,but on other xjs that wire is the feed out to the High /Low switch
  5. bensalf
    yorkshire ,england
    sorry, XJ550H got there whilst i was typing
  6. XJ550H
    you gave a better discription
  7. Lars Antonsen
    Denmark
    WOW!
    You guys are the best! :-D
    It works, the starter turns and the engine cranks! Tomorrow I'll fix the fuelhoses etc. and then hopefully get the engine running.
    I'm very happy and thankful :)
    Lars
  8. Lars Antonsen
    Denmark
    It's alive! :-D Thank you so much!
    Perhaps, if you are able to help me with the wiring on the left handlebar -I will post some pictures of the main wiring/handlebarwiring tomorrow? :)
  9. bensalf
    yorkshire ,england
    i replied to your other thread, Lars
  10. a100man
    a100man Well-Known Member
    Bedford, UK
    Looks like you're going to need some mudguards (fenders in US) too or things will get messy quickly - not to mention front forks like to be braced.
