new suzie project
Discussion in 'Hangout Lounge' started by cutlass79500, Feb 4, 2014.
  1. cutlass79500
    lawrenceville georgia
    Ran across a pretty good deal i think . Gs 450l the guy knows nothing about bikes at all. Was going down the street and the bike just shut off and would not start up again. will check out make sure its not a bad motor but i do not think so i believe its the ecu suzukis have the same grounding problem as yamahas. check compression and usual stuff guy wants $300 obo if i can talk him down might be able to make a few bucks on it help fund my other projects.
  2. randyd81
    randyd81 Member
    St Joseph Missouri
    Re: Going to check this out tomorrow
    Looks like a steal to me. Should be able to flip it with good profit fairly easy
  3. Kornbread
    Kornbread New Member
    ohio
    If your like me, its hard to turn down a $300 bike. Especially one that looks that decent!
  4. cutlass79500
    Headed over there at 1 pm tomorrow. Love cheap bikes. Hopefully its ok
  5. cutlass79500
    Picked it up today let the fun begin
  6. bigfitz52
    Maybe it just ran out of gas or he forgot to turn the tap on (if it's not vacuum operated.)
  7. cutlass79500
    Actually i believe it has a bad stator. He said he was looking for someone to check out the wiring his new battery kept going dead .If it is $56.00 .Have to go thru the front brakes clean the tank and carbs
  8. adrian1
    adrian1 Active Member
  9. mtnbikecrazy55
    Gotta love a cheap rideable bike
  10. cutlass79500
    Found out something went wrong in the petcock. The 5 year old gas was still thin but smelled like sweet alcohol. Cant get air to go thru the petcock with compressed air even on prime. Ordered a new petcock. Tank was in bad shape above the fuel level about 1/2 full its not rust but black crap looks like it might have been leaking water thru the key hole. Got it out back under the gazebo electrolysis. Was really careful pulling the carbs moved the air cleaner back loosened the clamps put a screw driver between the carb body and rubber intakes. pried real lightly the carbs fell off. The boots shrank so much they came right off the metal flanges that attach to the heads. Ordered the new ones pulled the carbs apart 1 was dry had no gas when it stopped running
    . They are 34mm Mikunis easy carbs to work on everything is clean blown out have to sonic clean them blow them out again put them on make sure it runs before adjusting the valves and polishing ect.
  11. cutlass79500
    They look kinda like our e model. Mine is the cruiser l model with a cut down seat
  12. cutlass79500
    Stator was bad. Cleaned up the carbs fired right up. Doing all the maintenance now brakes valves ect. While i am waiting on the last valve shim pulled all aluminum parts off motor peg brackets ect polishing them turning out well before and after pics
  13. Buschkj24
    Buschkj24 Member
    Wisconsin
    How did you polish them like that? My maxim needs it bad!
  14. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Lookin good.
  15. cutlass79500
    Wet sanded then took it to my bench top buffer with white rouge. Then finished it off with a couple coats of purple metal polish for protection
  16. cutlass79500
    a few of the other parts
  17. mtnbikecrazy55
    should turn out nice!
  18. Buschkj24
    Buschkj24 Member
    Wisconsin
    Thanks for the tip, do you wet sand with 1000 or 1500? That bike is looking great!
  19. cutlass79500
    Actually most was done with 500 i use it till it gets so warn out its like paper lol.
    Bike is getting there motor is all back together valves adjusted No fun when some of the shim numbers were rubbed off. I bought like 10 shims at 7.00 ea for 4 valves. They were all tight could not get a .0015so had to measure and guess on the shims But they fit all the old gs air cooled bikes 29.5mm. New stator is in rear wheel is off now getting a once in a lifetime clean up. Suzuki had their stuff together the rear sprocket has like a teflon coating black non stick. sprayed some simple green on it used a parts brush 18k worth of grease grunge came right off anyone that has ever cleaned a sprocket knows how bad they can be to clean. Striped the drum also brake shoes look great no delam on these puppys. polish the wheel and 1 shock put it back on tomorrow. Waiting for my battery to get here before carb sync. Next week i will order my ss line new master and kit for caliper polish the front forks and it will be about done
  20. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Looks super clean, good job.
  21. bigfitz52
    Tires?
  22. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Nice. I need to learn how to do this.
  23. cutlass79500
    Yea it has 2 lol . Ordered 2 kenda or how ever you spell it. Hopefully this project will be done in a few weeks so i can send it down the road. Think i found my next project. I probably will not make a bunch of money for it but who ever gets it will be getting a nice bike with all maintenance done.
  24. cutlass79500
    Well little suzie is about done got to get the new tires mounted. Took it for a ride down the street today runs fantastic does not look to bad either. Have a little over 600 in it not to bad considering all new front brakes new stator shims for the valves 2 tires and gaskets chain. Just have to figure out why the speedo quit probably from sitting. Need to move the slide clips up on the 350rd first and make sure its ready for the season
  25. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Nice job Cutlass! I always drool when I see shiny things
  26. cutlass79500
    I am very happy with it its a great around town bike has so much more torque then any little bike i have driven plus will get 60 mpg
