newbie in uk...front brake switch connection...!!
Discussion in 'XJ Modifications' started by Rags110-2007, May 11, 2014.
  1. Rags110-2007
    Rags110-2007 New Member
    United kingdom
    Helloooo everyone in the good old usa...just joined the forum having bought a 550 maxim import well pleased with the bike...started to strip it down for painting and have slowly been putting everything back how it should but cannot find for the love of trying where the connection is for my front brake switch from the lever,thought I labelled em all up but this one got away...has the male bullet connectors from the lever.......????? 8O 8O
  2. dean.james
    dean.james New Member
    west yorkshier
    Put some images on and we will help you fig it out mate
    This is inside my ligth and it is the green one at front
  3. bigfitz52
    No, that green one at the front is your clutch lever safety switch. http://xjbikes.com/Forums/viewtopic/t=30354.html
    But the connections are in the headlight bucket; in the pic below you can see the leads (green wire w/yellow stripe & brown wire) plugged in, upper right. They plug into wires of the same color; note that there are both "brown" and "chocolate" colored wires; the darker (chocolate) ones are used for the turn signals.
    (The connectors with the red circles around them are the items that need to be unplugged to remove the cluster, this is a 550 Seca so there are more of them than your Maxims.)
  4. dean.james
    west yorkshier
    Sorry fitz my back fitz was right green is cluch switch
