Newbie Starter Cable Question
Discussion in 'XJ Technical Chat' started by rocs82650, Jan 28, 2012.
  1. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Isn't the cold start or "choke" cable suppose to "seat" in the sleeve on the left hand control switch? I've bought a aftermarket cable that is suppose to custom fit my 650j. It just slips in and out of the sleeve on the control switch. Here's the kicker, the damaged OEM starter cable does the same thing. I don't want to buy another if it's going to do the same thing. Help.
    Thanks,
    _________________
    rocs 82650
    19k miles
    1st bike
  2. MiCarl
    Take out the slack where it clamps to the carburetor rack.
  3. schmuckaholic
    California
    Same problem here, and I've done what you suggested -- it's still a tad too long. (shrug)
  4. bigfitz52
    They WILL "fall out" when the lever is in the the "full off" position; that's how you can disenage it from the housing. Both of my 550s are like that too.
    All you need to do is gently "close up" the little pocket on the perch that the ferrule goes into so it slightly grabs the end of the cable. And, as Carl said, ensure it's properly adjusted.
