Next step.
Discussion in 'XJ Modifications' started by one_fast_ls1, Mar 1, 2008.
  1. one_fast_ls1
    one_fast_ls1 New Member
    Well, I've been away from the bike for a while, but i'm back at it, and tearing it down piece by piece.
    First - brakes. I got my master cyllinder off the bike, and want to replace it with a nice handlebar mounted one. Who makes one that'll work with my dual front brakes?
    second - Gas tank- My gas tank is really beaten up from the previous owner. Either I need to fix it (doubt that) or get a different one. Has anyone put a gas tank from an xs1100 on their bike? Just want to know how it looks/mounts. I can find those easier than I can ever find xj750 seca gas tanks, and I like the added fuel capacity.
    I got everything I could off of the front to see how I much I could clean up the looks of the bike, and i'm amazed at all the crap that they put on these things! Guess that's just my opinion- i'm a minimalist when it comes to bikes.
    Here's the headlight i'm going to be putting on. http://www.denniskirk.com/jsp/product_c ... 102&mmyId=
    And i'm going to use the single digital gauge that everyone talks about. (the name escapes me right now.)
    Once I figure out the gas tank situation, i'll worry about the seat and rear fender- I know i'm going to have to change them out if I use a different gas tank. They have to be changed anyways.
  2. RickCoMatic
    You should probably try and repair the tank. If you have a "Rent-All" Store near you; you can rent a Copper Rivet Welding Puller. The tool spot welds copper rivets on to the tank and has a tool you use for pulling out the dents.
    Work from the outside edge of the dent towards the middle. Get the contour close enough to be filled with MarGlas and sand and shape the MarGlas.
    Finish it off with regular Bondo.
  3. Jim77xlh
    Jim77xlh New Member
    Clifton Park, New York
    You can buy that tool at Harbor Freight. I was just there two days ago, and i think it was only $129. I pointed it out to my friend, because I have a dent in my tank and I'm thinking of getting it to fix it.
  4. MiCarl
    Jim,
    What bike is that in your avatar?
    Do you think one of those fenders would fit on my Maxim?
  5. bluzglide
    bluzglide Member
    If you're talking about the brunette fender, I don't think they are available yet. They're still in prototype stage.
  6. one_fast_ls1
    I'll have to check that out- could always use a new toy around here, even if it doesn't work. The reason I say that is because it's probably not going to happen. it's not just a dent... it looks like somebody took a hammer and took out their aggression on one spot of the tank. It's caved in where the dent is, and pushed out on the side... it's right by the body line- where the steel is the strongest.
    I've got a few tricks up my sleeve for fixing the gas tank, I just want to know what gas tanks fit well, just in case it can't be fixed. And no- i don't care if I have to fab up a new mount to bolt the gas tank down...
    By the way- let me know when that fender comes in redhead! :wink:
  7. Jim77xlh
    Jim77xlh New Member
    There's a fender in my avatar? <G>
    I'm not sure which model it is. I found it online and liked the looks. The bike's not bad either.
  8. Mixam
    Mixam Member
    Belleville, Ontario
    It's a Ducati 996. Hence the reason a hot brunette is laying on it... lol
  9. bluzglide
    bluzglide Member
    What??? You think that a hot brunette would lay around on a nice 650 Seca? Shame on you...go to the Ducati forum! Do not pass go, do not collect $100.
  10. danno
    danno Member
    Union Springs,New York
    I have an '82 Seca 750 tank that needs paint,and has a few minor dents. $50 plus shipping from 13160.No cap or petcock,but fuel sending unit is still in place.
  11. RickCoMatic
    Let's try to contain ourselves and recognize that there are women members of this Forum and remarks like that are best left ...
    UN-typed!
    I'm blowing the whistle and throwing a flag on that play.
    Let's not go there.
  12. xj750_Pete
    xj750_Pete Member
    El Monte, California
    for the master cylinder, they sell some nice ones at dennis kirk. I plan on replacing my master cylinder on my bike as well. THe design is smilar to that of sport bike master cylinders. I'm not sure about the SECA, but on my maxim the master cylinder and the mirrior are mounted on the same unit, so replacing the master cyl means either not having the mirror or finding some way to mount a bar end mirror. Dennis kirk also sells handle bar mirrors too, but after looking at the space on my handle bar, i am not sure if theres room to mount it.
    Anyways, i dont know if they will work or not, but you can give these a try. Look up Shindy or Magura at dennis kirk. They got a bunch of master cylinders.
  13. one_fast_ls1
    Alright danno, i'm at 48044. If you could figure out the cost of shipping, I would appreciate it.
    I've been looking through dennis kirk, pete. Thanks. I can't believe they have master cyllinders for 437.00! I didn't pay much more than that for my bike! It's going to take some thinking about making the setup work... but i'm always up for a challenge.
  14. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    I bought a really nice two-disc master cylinder for my old Seca turbo from Parts N More for $76. Worked a treat and matched the bike perfectly. It smartened the braking up (along with braided lines) since the bore size was bigger, moving more volume with every bit of lever stroke.
  15. blackjack550
    blackjack550 Member
    san pedro california
    you can pop out the dent easy just block off the petcock fill it with water and put the tank in the freezer but just keep an eye in it so u dont but the seams.....in other words dont overfill it just do that and the big dents will pop out easy.
  16. blackjack550
    blackjack550 Member
    ohh and by the way women shouldnt be on the front of the bike posing they should be on the back holding on.....im 17 and i know that one come on guys ..
