NGK Non-resistor plug cap for cyl 2 & 3?
Discussion in 'XJ Technical Chat' started by KA1J, Sep 20, 2012.
  1. KA1J
    KA1J Member
    Groton, CT
    I'm trying to find a non-resistor plug cap for Cylinders 2 & 3. I've found the part numbers for the ones to fit 1 & 4 but the NGK website is not intuitive and I can't find the matching set with the long shank & short 90 degree top that has no resistor inside.
    Any suggestions as to number and matching source?
    Thanks.
  2. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    So why do you need non resistive plug caps on these two? All I have ever found are short 90 degree and those I got from chacal. The reason I went to non resistive ones is that the non resistive plugs for these bike are no longer available in Canada.
  3. KA1J
    KA1J Member
    Groton, CT
    I am using NGK BPR6EIX Iridium spark plugs and they have a resistor built into them. I have Dynacoils and 8mm solid core spark plug wire and want to remove the additional resistor in line, the one in the cap. I can remove the resistor in the long shank caps for Cyl 2&3 and replace it with solid brass rod but I can't access the resistor in the short shank caps for 1&2.
