No brake pressure 81' xj650 maxim
Discussion in 'XJ Technical Chat' started by Brandenxj650, Jul 1, 2016.
  1. Brandenxj650
    Brandenxj650 New Member
    Elizabeth,PA
    I rebuilt the master cylinder and calipers and cleaned all the brake lines. I used a syringe and bled the brakes from the bottom up and also vacuum bled them with a mighty vac. I even bled them the traditional way but no matter how much I bleed them I can't get enough pressure to push the piston at all. I know there is some pressure because when I open the bleeder screw and press the lever there is brake fluid that will shoot out. And yes I close the bleed screw before I depress the lever so air doesn't renter the system. Is there any other reason there could be no pressure besides there being air in the system? I'm also confident I have the master cylinder built correctly.
  2. ant797
    ant797 Member
    western australia
    check your slides on the calliper/ callipers are moving freels side to side they might be stuck in an offset position other then that perhaps you need to rebuild the piston seals within the calliper ...a way to tell if the slides are offset stuck is one pad will be touching disk the other will have a gap
  3. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Are those the original brake lines?
    Cleaning 35 year old brake lines won't help. They should be replaced, preferably with stainless steel braided lines.
    The old rubber will balloon and not direct the pressure to the caliper piston.
    Order replacement ones from XJ4Ever.
  4. ant797
    ant797 Member
    western australia
    good idea to replace everything piston seals brake lines etc but as i said the slides might be siezed they also need servicing
  5. k-moe
    Vibratory sander. No sanding pad. Start at the calipers and work your way up to the master cylinder. The air will come out.
    Lightcs1776 and mrdawson like this.
  6. jayrodoh
    jayrodoh YimYam
    Cleveland
    Define "can't get enough pressure to push the piston at all". Does the lever go to the handle bar when pulled in? If so, you still have air in the lines. Did you bench bleed the MC after the rebuild?
    If the lever is not soft/spongey and met with great resistance when pulling in, then you probably have an issue with the caliper itself.
  7. Brandenxj650
    Elizabeth,PA
    Thanks for the help, I got it working. It ended up just being air in the lines and was just a pain to get out.
  8. k-moe
    Re-bleed them after a few days of riding.
    Brandenxj650 likes this.
