No fuel flow in reserve position. Petcock problem?
Discussion in 'XJ Technical Chat' started by jamcam1999, Jan 31, 2010.
  1. jamcam1999
    jamcam1999 Member
    <a href="http://maps.google.com/maps?q=50.064192+-
    Does anyone have a picture of the proper layout of the petcock on the 1982 XJ650 Seca? I can't get fuel through it in the "reserve" position. Works ok in all the other postitions. Thanks in advance for any help.
  2. Creamsoda
    Creamsoda Member
    I have the same problem on my maxim, no flow only on the reserve side.
  3. RickCoMatic
    You first Test the Vacuum Valve.
    Hook-up a length of Hose to the Vacuum Port on the Petcock and take a Vacuum on the Hose.
    (Just placing the Hose to your lips and drawing a slight Vacuum will do.)
    If the Fuel Flows in On when there is a Vacuum and Fails to flow otherwise ... Open the Face of the Petcock and see that the Wafer is in the proper placement.
  4. jamcam1999
    jamcam1999 Member
    Which part are you calling the "wafer"? Do you mean the rubber or neoprene piece with 4 holes in it?
  5. RickCoMatic
    That's it.
    The Rubber Disc with the holes in it.
