no spark but coil is good
Discussion in 'XJ Technical Chat' started by benzelman, Mar 2, 2008.
  1. benzelman
    benzelman New Member
    vancouver canada
    Making leaps and bounds in my quest to ride the 81 seca 750rh. Following the forum suggestions i replaced that fuse box and wow what a difference. All my lights work and my start is way easier. Problem is that i have nothing on the 1 and 4 cylinder. I have pulled the coil and put in one from a buddys working bike and nothin.. i have to admit i have the heaviest 2 cylinder on the block! ANy sugestions??
  2. MiCarl
    Try your buddy's TCI.
  3. Robert
    Then check your pickup coils and the associated wiring between the TCI, pickups and coils. A bad ground will mess up the works as well.
  4. philbrewer
    philbrewer Member
    Livonia, MI
    I have this same problem except Im getting no spark on 2 and 3, with both coils testing good. How should I go about troubleshooting this?
  5. Robert
    If you swap the input plugs to the coils and the problem follows the plug, you know that it is something further up-stream. The TCI or a pickup coil. Otherwise, it is the coil for sure.
