No Spark on 1982 XJ550
Discussion in 'XJ Technical Chat' started by Erik O., May 29, 2017.
  1. Erik O.
    Erik O. New Member
    Iowa
    Hey Guys,
    I couldn't get my bike to start even though it is turning over and I cannot get a spark. I looked at the fuses, checked for wire damage, checked the spark plugs, and replaced the CDI. I'm not sure what to do.
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Check the battery voltage at rest and when cranking.
    You may be surprised that it is an easy fix.
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I always suggest trying to jump it with a good car battery. If it starts then you have a battery problem. If no, then it's probably something else.
  4. Erik O.
    Erik O. New Member
    Iowa
    Thank you for the suggestions. I checked the voltage of the battery and it was between 12 and 13 and I tried jumping it. Do you guys have any other suggestions?
  5. tabaka45
    Brunswick, Georgia
    One of the guys that really know the electrical system will chime in and tell you how to trace it. Electrical issues are tough but these guys seem to know how to fix just about anything.
  6. Killerkhezu
    Killerkhezu New Member
    Minnesota
    If you can find it, try removing the wires for the kick stand safety mechanism and remove them. They might be engaged like mine for causing a no spark issue.
    If you have a multi meter check to see if your ignition coils are getting power if they are this might be your issue.
  7. XJ550H
    start by ohming out the ignition system.
    ignition coils primary leads
    sparkplug wires
    sparkplug caps
    sparkplugs.
    when you reinstall the spark plug caps trim about 3/8 inch off the end
    ohm out pickup coils which is done at the tci connector gray wire to black wire , then orange wire to black wire,
    specs
    Pick-up coils:
    650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
  8. XJ550H
    if you still have glass fuses you may want to upgrade to blade fuses
    remove the fuse to check if the ends fall off.
    next you want to chase the voltage
    key on 12 volts both sides of fuse clips.
    test voltage at red/white wire on tci
    test voltage on ignition coils both wires at the connector under the tank
    when you disconnect any connectors clean them with electric spray cleaner and apply dielectric grease. Use this grease on spark plug wires when you reinstall the caps.
    the battery voltage test is measure the battery before turning on key . step 2 is check voltage as the starter is cranking this voltage must stay above 9.8 volts .
    your voltage numbers sounded high at 12 to 13 volts
    let us know what you get for numbers.
    also are the spark plugs new?
    Stumplifter likes this.
  9. hogfiddles
    Voltage at 12-13 sounds fine. What does it drop to when you engage the starter, though?
  10. XJ550H
    did you ohm out the ignition system yet ?what did you get for numbers.
    after you check the voltage drop when using starter button , if you want I will test your tci for you in my bike.
    start a conversation with me just pay postage both ways
  11. Erik O.
    Erik O. New Member
    Iowa
    Hey Guys,
    Thank you so much for the information! I have not had a chance to dig deeper into it yet but I will let you guys know what I find out. Thank you!
