no spark
Discussion in 'XJ Technical Chat' started by fishhookxj, Oct 16, 2012.
  1. fishhookxj
    fishhookxj Member
    FLORIDA
    my engine i just picked up was siting around for a year it has great compression, it turns over just i have no spark i change my relays, tci, and i changed plugs but i still have no spark.
    please help with any info or idea thank you
    im also in the process of changing over the fuse box to blade style.
  2. fishhookxj
    fishhookxj Member
    FLORIDA
    COULD MY PICK UP COIL BE BAD?
  3. KrS14
    KrS14 Active Member
    St Marys, Ontario
    If you have no spark issues, don't try to fix that until you change over your fusebox. You may find that you have spark after changing the fusebox to new.
  4. fishhookxj
    fishhookxj Member
    FLORIDA
    ok ill let ya know what happens after i do the change
  5. fishhookxj
    fishhookxj Member
    FLORIDA
    ok i got the new fuse box in and all set up i get lights, it turns over, but still no fire or spark!
    the engine did sit for a while but has good compression and the oil was clean it now has new oil, new plugs, new filter, new gaskets, reman starter and good battery, im not sure on the coils or relays i did replace relay but they were used. and my tci box was working fine on last engine
  6. fishhookxj
    fishhookxj Member
    FLORIDA
    ok i got her to fire up and start but has a back fire
