No Turn Signals, well, unless
Discussion in 'XJ Technical Chat' started by buzz81mach, Sep 6, 2012.
  1. buzz81mach
    buzz81mach Member
    Crawfordsville, IN
    Hi everyone, I am having an issue with my turn signals. When everything is hooked up correctly, I get no turn signals. The lights all light up but will never flash. Funny thing is, I know it works. I accidently hooked up the right switch wire connector to the turn signal connector on the main harness andeverytime I hit the start button, the right turn signals will flash. But when I would hook it all up correctly, nothing ever happens. I did buy another left hand switch, but it still does not want to work. Anyone have any ideas? I just don't want to have to buy an aftermarket turn signal wiring kit if I do not have to. Thanks.
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    are you using the stock signals? If you are using aftermarkets that draw less power you will need to swap out your flasher with an electronic one.
  3. buzz81mach
    buzz81mach Member
    Crawfordsville, IN
    Yes, everything is stock.
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Are you sure you have 27 watt lamps in your signals.
  5. buzz81mach
    buzz81mach Member
    Crawfordsville, IN
    I will make sure and check first thing tomorrow morning. It is just weird that it will work if I swap the connector to the wrong one.
  6. MN-Maxims
    Saint Paul, MN
    Maybe some how you hooked up both filaments which created more resistance and that triggered the flasher to work.
  7. buzz81mach
    buzz81mach Member
    Crawfordsville, IN
    One quick question that pertains to this. Will the lights still flash if the back lamps are burnt out, or is it like the old Christmas trees when one light goes out, they all go out? Not my issue, but just something to know just in case it happens.
  8. MN-Maxims
    Saint Paul, MN
    If one of the two lamps burn out it will not flash
  9. tombo
    tombo Member
    San Francisco, CA
    Buzz - you might double check that your brake light is working correctly, as it is on the same circuit. (yikes!)
  10. buzz81mach
    buzz81mach Member
    Crawfordsville, IN
    I haven't been able to check my bulbs yet, but yes, my brake light does work. It's been a crazy past few days.
