No vacuum on carbs 1 and 2.
Discussion in 'XJ Technical Chat' started by hordave, Apr 1, 2010.
  1. hordave
    hordave Member
    Kitchener, Ontario, N2B 1V1, Canada
    I tried doing a carb sync on my 1984 xj750 Maxim last night with the Yics tool i made and Carbs 1 and 2 had no vacuum at all. Now I beleive that there was a problem with my YICS tool.
    However just for kicks and giggles I put the YICS plugs back in and checked it again with the Carb Sync Gauge and still nothing on carbs 1 and 2. Carbs 3 and 4 worked fine.
    We then switched the hoses from 3 and 4 to 1 and 2 to make sure it wasen't the sync gauage and still nothing.
    Any ideas what to check or am I missing something.
  2. hordave
    hordave Member
    Oh ya, just to add. The bike doesn't seem to be running to bad. Lots of pickup and not really ruff. Just a little hard to start when cold, it always does start though.
  3. TIMEtoRIDE
    Probe down inside the tube on the intake, with a thin wire, or the red tube from WD-40. . .compare to number 4.
    Problem is- - if there's a blockage, you would want to retrieve it,
    and not just let your engine eat it.
    That would mean pulling the carbs. :cry:
    Just a thought- - are your boots smeared with rubber cement??
    Some people smear them on the inside also, blocking the hole.
  4. MiCarl
    Way out of sync. 1 and 2 doing all the work, 3 and 4 closed pulling lots of vacuum.
