noob on oil change advice
Discussion in 'Hangout Lounge' started by jgstudios, Jul 19, 2008.
  1. jgstudios
    jgstudios New Member
    Doing first oil change on my '81 seca 750 today. I've posted a question in the XJchat but this one is a little different. SO...maybe I'm being anal about it, but as far as crankcase capacity, I notice my CC cover shows 2500CM^3 on it. that is 2500 cubic centimeters. I think I'm right on that. So is that the true oil capacity? Also how crucial is it to get it exact. Since it's a small engine as opposed to my deisle truck I was concerned that overfilling would be far more problematic. I was thinking one of these might help
    http://www.wirthco.com/4.5-qt_measurer_ ... p-303.html
    Is this going to far? Should I just eyeball the level in the window?
    Anybody know the conversion from cubic centimeters to quarts? All I find is food cooking measure conversion on the net.
  2. acergremlin
    acergremlin Member
    NE UK
    I just slowly fill it to the top of the window and let it settle, start bike for a few seconds to let oil circulate, turn it off and let it settle for a few mins and top up as nessasary, then repeat until the level stays at the top.
  3. jgstudios
  4. jgstudios
    OK, my conversion and capacity obsession is over
    Crankcase capacity is 2500 CM^3 = 2.64 US qts.
    But with the filter you need 2.96 qts.
    and the eyeball method works fine.
    Thanks to all for the advice
    Oil job is done and the Seca runs fine.
