NOS O-rings or Viton for Cylinder Head Dowels
Discussion in 'XJ Technical Chat' started by jayrodoh, Jul 25, 2018.
  1. jayrodoh
    jayrodoh YimYam
    Cleveland
    Not an XJ question but not getting any responses on my other forum for the particular bike. If this thread needs to be moved please do so.
    I am redoing the head on a Kaw and the o rings for the dowel pins are NLA. There are NOS ones on eBay etc. but I'm wondering if sourcing a new Viton or other material would be better than something that sat on a shelf for 20+ years.
  2. turpentyne
    turpentyne Active Member
    Desert SW
    Just glanced at a site that lists it depending on the storage methods, and giving an example with only 3 year shelf-life.. But at the top is a chart listing what looks like 15 years - if I read it right. I only glanced. Not sounding like a vote for NOS.
    Here's what I was looking at: https://www.marcorubber.com/o-ring-shelf-life.htm
  3. turpentyne
    Desert SW
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    Looks like shelf life depends on the type of material, assuming good storage conditions. I have no idea what the NOS ones would be. I'm leaning towards new ones, not sure what material is suitable for head gasket conditions.
  5. k-moe
    Are they a special shape?
    If not then measure them and buy new from an o-ring supply house (depending on the condition of the old ones, you may what to get an NOS set to take measurements from).
    If they are a normal shape, but of a special size, you can buy o-ring material and glue to make the size that you need.
    Colin 85 700 likes this.
  6. jayrodoh
    jayrodoh YimYam
    Cleveland
    Nope, normal looking o ring. I think I will get a NOS one like you mention and measure/replace.
  7. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    A good quality gasket kit should come with said o-rings, you are replacing the head gasket and valve seals while your in there right? I believe Athena still makes kits for most vintage bikes.
    If it doesn't have the o-rings, a bearing supply shop should be able to get appropriate o-rings by measurement (remember they are metric! Measure in mm! ). Not sure if I'd trust 20yr old rubber.
  8. Polock
  9. turpentyne
    Desert SW
    O-ring guages & sizing cones...just great. Now I see a new tool on that page I must have!
    My checking account is not happy with you! Hehe!
  10. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    The oring store .com
  11. jayrodoh
    jayrodoh YimYam
    Cleveland
    Of course. I'm pretty through on my projects. I opt for OEM whenever possible, had some bad luck with aftermarket gasket kits in the past and don't need the full set for this. Vesrah does make a full set but it far exceeds the cost of a few orings.
