Not charging ?
Discussion in 'XJ Technical Chat' started by XJ900F uk, May 18, 2017.
  1. XJ900F uk
    XJ900F uk New Member
    UK
    Small wonder the PO must have had no charging !
    Someone trapped the stator output wire so that it was rubbed through by the rotor ...
    Franz, Jetfixer and Stumplifter like this.
  2. hogfiddles
    Face-palm
    Jetfixer likes this.
  3. Jetfixer
    At least you found the problem.:D
  4. Timbox
    Timbox Well-Known Member
    Yes was to track that down, good job.
  5. Franz
    I have the same problem and getting another multimeter to double check the Stator and Rotor resistance figures which are slightly high at the moment. But I noticed the green and brown wires, brown has o.3 Ohms resistance and the green has 5 Ohms resistance. As my meter is reading 0.2 Ohms when I put the positive leads together means the brown has 0.1 Ohm resistance and the green has 4.8 Ohms, surely this figure is too high and the supply voltage is too low as a consequence for the alternator to work. Any advice on this thanks?
  6. Franz
    Unfortunately my charging problem has not been fixed yet, good job finding it XJ 900f UK.
  7. XJ900F uk
    UK
    It was discovered by accident when I removed the endcasting from the alternator whilst trying to make enough room to fit a standard airbox on an installed engine.
    My late father I think called it Murphy's Law in the aero industry. "If a part can be installed incorrectly - someone will eventually do it."
    Wires not actually severed but definitely shorted together. I have today tried pushing them apart and re-insulating with silicone. We'll see.
    Franz likes this.
  8. Franz
    Hi XJ900F your father was right, Let us know how the repair goes.
  9. XJ900F uk
    UK
    After silicone had set I checked wires for both continuity and non-contact.
    Then wrapped with some self-amalgamating tape to tidy things up and replace the worn-away braid tube section.
    Can no longer Edit first post but of course those two wires to the brushes are for what we call the "exciter" circuit. The three wires from the stator were fine.
    With hindsight I wish I'd made a thin plastic strip to go under the nearest Phillips screw and hold back the wire behind/around and not over the plastic moulding - so 'trapping' simply could not happen again.
    When I renew the brushes I'll be making that tiny mod.
  10. Franz
    Yes quite right wires getting trapped and damaged like that is no good.
