Not firing on cylinders 1 and 3??
Discussion in 'XJ Technical Chat' started by Kevin_Peuhkurinen, Mar 25, 2012.
  1. Kevin_Peuhkurinen
    Kevin_Peuhkurinen New Member
    Hey all... could use some advice. When I put my '82 650 away for the winter it was all running fine. When I took it out last weekend, cylinders 1 and 3 are not firing at all.
    I assumed at first that it was a carb issue so I took the carbs apart and gave them a good cleaning, then adjusted the float levels. Still not firing. Spark tester shows that the plugs are getting juice. Compression tester shows decent compression. Carbtune shows a vacuum.
    It shouldn't be a coil issue since they are on separate coils but I tested the dyna coils anyway and they test fine.
    Anyone have an idea as to what is the likeliest issue? Bad ground (perhaps a mouse chewed through a wire)? Ignition unit? Plugs? Valves?
    Thanks!
