Not starting
Discussion in 'XJ Technical Chat' started by Faster, Jun 22, 2016.
  1. Faster
    Faster Member
    Pasco wa
    Well guys I tried to fire up the beast today I put a little gas in tank squirted gas in each carb its firing at spark plugs but all I got was a want to start and pop when I let off of starter switch I even squirted some starting fluid in carbs the bike hasnt ran for maybe 10 years I thought squirting gas in each carb would do it and should I be using premium gas . could someone tell me if firing order right #4 on right out side
  2. hogfiddles
    You're carbs are clogged and need thorough teardown/cleaning/rebuild
  3. Jetfixer
    Agree ..tank will need cleaned and a FULL church of clean for your carbs. Valves checked and adjusted....
  4. Saltydog
    Saltydog Member
    Eastern NC
    "bike hasnt ran for maybe 10 years"
    Agree....You need to clean the carbs.
  5. k-moe
    Among other things. I gave him a short-list in a conversation earlier today.
