Oil capacity in 1982 xj650
Discussion in 'XJ Technical Chat' started by Bigdaddy, Jun 9, 2010.
  1. Bigdaddy
    Bigdaddy Member
    Salem, OH
    Does anybody know the correct oil capacity? How many quarts of oil should I add after changing it. Seems like a stupid question, but have gotten different answers from different people (including Yamaha Shop). No I haven't gotten a manual yet, still waiting.
    Bugzy likes this.
  2. bigfitz52
    Your bike has the answer cast into it.
    Just to the rear of the filler cap are some numbers cast into the cover; if your 650 is the same as mine, it says "2500cm3." That's 2500cc's or 2.5 litres. (2.6qt.)
    HOWEVER: The oil level, checked on the centerstand, should be slightly above the upper marks, with just a "bubble" showing at the top. This will require a 200cc or so overfill; the reason for this is to keep the oil level sensor happy during hard acceleration.
    So just under 3 qts.
    As far as which oil, do a forum search, it has been discussed to death; or just use Castrol 4T 20W50 "motorcycle oil."
    Richard Krzeminski and Bugzy like this.
  3. Bigdaddy
    Bigdaddy Member
    Salem, OH
    You da man Fitz. Thank you.
  4. Ian Dick
    Ian Dick New Member
    Edmonton
    thank you, extremely helpful!
