oil change
Discussion in 'XJ Technical Chat' started by nickbrit16, Aug 11, 2012.
  1. nickbrit16
    nickbrit16 Member
    Ohio
    Will 10w-40 or 20w-50 work on my 1982 xj650?
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Use 20-50 motorcycle oil with out friction modifiers
  3. nickbrit16
    nickbrit16 Member
    Ohio
    so 10w-40 wont work?
  4. bigfitz52
    10W-anything is not a good idea in warm weather.
    Yamaha specifies 20W40 for anything above about 60 degrees; since 20W40 isn't that easy to find, you can use 20W50. Motorcycle oil; not car oil. And it's best to avoid synthetics.
  5. nickbrit16
    nickbrit16 Member
    Ohio
    Ya I just went ahead and bought 20w50 valvoline.
  6. bigfitz52
    Motorcycle oil, right?
    If you find the FRAM CH6003 filter; they come with both o-rings. Around here (MI) Advance Auto usually has them on the shelf, O'Reilly's is a 50/50 shot, and AutoZone a complete crapshoot (although the 'Zone carries Castrol 4T M/C oil for cheap and usually has NGK plugs.)
    The dealer will charge you $14~$18 for a $5~$7 filter.
  7. nickbrit16
    nickbrit16 Member
    Ohio
    Ya motorcycle oil. I had a Emgo filter that the PO gave me. I wonder if the k&n filter is worth a shot?
  8. bigfitz52
    K&N oil filter? Sure, good product. The only reason I recommended the FRAM is because it comes with both o-rings.
  9. Ross1
    Ross1 Member
    Syracuse,NY
    http://www.thefirstsyntheticoil.com/Files/g-2156.pdf
    Interesting article. The drawback to the results is that it barely touches on wet-clutch performance.
    I was going to replace my clutch plates before next spring, am tempted to
    postpone it and try either Mobil or Amsoil.
    The results in different categories are so mixed,it is difficult to really compare. But if the clutch plates slip with the expensive juice I'll go back to Castrol/Valvoline and keep up with frequent changes.
  10. bigfitz52
    The effect of synthetics on the clutch varies by condition of the clutch, etc. An original clutch in a 30 year old bike should have its plates and springs replaced regardless.
    The real drawback to synthetics in our bike is its known potential to affect the STARTER clutch.
  11. Sabre
    Sabre Member
    Lansing, MI
    Amsoil made my starter clutch slip so bad it was simply luck that I could get the bike started after many, many attempts.
