Oil cooler and oil filter housing
Discussion in 'XJ Technical Chat' started by Curt Henry, Dec 13, 2016.
  1. Curt Henry
    Curt Henry New Member
    Minnetonka Minnesota
    82 Yamaha XJ650RJ Seca
    The bike came with a Lockhart oil cooler. Do oil cooler perform much of a function on this bike? The plate between the engine block and the oil filter housing makes it a bear to change the filter n I do not like how close the rubber hoses pass by the exhaust. I have owned Airhead BMW motorcycles and on this bike a cooler does not make much of a difference in oil temperature.
    What sizes is the oil filter bolt/oil bypass? A 11mm will not fit and a 12mm 6 point socket is very sloppy. I have measured the hex and found it to be .459 = 29/64 = 11.7mm. Sooner or later using the 12mm is going to round over the hex.
    Third question. I had not ran the bike in a couple of months and the vacuum operated petcock along with the float valves failed leaking gas into the engine. I noticed the problem when the bike started leaking from the left side shift lever cover. Removed gas tank and drained the engine oil. I currently have the shift cover, clutch cover off the bike and the oil filter removed/oil drain plug out, allowing the gas to evaporate from the engine.
    Should I remove and clean the clutch plates or is airing enough? I plan in the spring to run the bike a few miles and change the oil to make sure I cleared the engine of the gasoline.
    I am planning to replace the float needle valves assemblies and install a manual petcock.
  2. Jetfixer
    Rebuild the petcock..kit is like 20$ ... the oil cooler does help if you live in hotter climb , you may have an after market cooler so it is possible someone used a standard fastner rather than metric ??
  3. k-moe
    The oil cooler does help ( but is not required). They came as standard everywhere but the U.S.
    Lockhart is a US company, so all their fasteners during that era would be SAE, instead of metric.
    jmilliken likes this.
