Oil help
Discussion in 'XJ Technical Chat' started by Mustang, Jun 17, 2016.
  1. Mustang
    Mustang Member
    Masonville
    Away from my ownersrepair manual how many qts fits in the xj750
  2. TheCrazyGnat
    Central PA
    2.8 liters or 2.959 quarts with oil filter change. 2.5 liters or 2.642 quarts without filter change.
  3. Mustang
    Mustang Member
    Masonville
    Awesome and I'm having a heck of a day I'm so excited about the first fire up after this 6 month rebuild fiasco is it 15w40
  4. TheCrazyGnat
    Central PA
    Yes sir
  5. k-moe
    In case your memory fails you, the oil capacity is cast into the clutch cover, right next to the oil cap. A slightly over-full fill will leave just a bubble at the top of the window with the bike on the center stand. Makes it easier to detect leaking float needles, gives a bit more oil for cooing, and still keeps the working level low enough to prevent foaming.
  6. Mustang
    Mustang Member
    Masonville
    Well I got everything back together and wouldn't you know it leaks gas. Must have pinched a seal on the fuel intake nub. FML got to take the damn carbs out and apart again
  7. TheCrazyGnat
    Central PA
    Bummer, it's always something, ha ha. You'll be able to do this in your sleep soon!
  8. Mustang
    Mustang Member
    Masonville
    I got them out in 2 min lol
    TheCrazyGnat likes this.
