Oil indicator
Discussion in 'For Sale, Trade/Swap, Wanted' started by spalomo81, Feb 7, 2013.
  1. spalomo81
    spalomo81 Member
    i went to go start up my bike and decided to check on the oil through the glass, but saw nothing. SO i decide to put more oil and still see nothing....what do i do? and how do i know if i put too much oil or should i put more?
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Spalomo81,
    Put your bike on the centerstand (not side stand); wait for it....the oil will drain back down and you will be able to read it. You should have a small air space just above the oil level which at max should be level with the outside full mark on the clutch cover. If you've put too much oil in it drain some of it out until it's at the proper level. You do not want to run your bike with too much oil in it. Hope this helps.
    Gary
