oil leak location
Discussion in 'XJ Technical Chat' started by cgutz, Jul 18, 2017.
  1. cgutz
    cgutz Well-Known Member
    SE South Dakota
    After a ride I have oil on lower right side of engine. The oil drop collects under the bolt housing below and in front of sight glass.
    Using talcum powder it looks like clutch cover main seal. It is dry above this area and behind.
    Anyone have other thoughts?
  2. Timbox
    Timbox Well-Known Member
    Looks like you read up how to find it and you did! Now don't over tighten that and brake it off, I know it would cross my mind to jump on that bolt and tighten the heck out of it. The best bet is to drain the oil, take the cover off and either replace the gasket or get some liquid or spray gasket maker and tough up that area of the gasket.
    Also make sure that both surface areas are flat and free of anything that might be sticking up. Little slivers of metal or gasket might have caused the problem in the first place. Take your time and as you pull the cover off, make sure you pull the gasket off slowly and maybe follow it with a nice flat head screw driver and it should pull off in good shape. Keep us posted.
    k-moe, Jetfixer and Toomanybikes like this.
  3. Jetfixer
    Agree with Timbox ... you could try lossening bolt and set to proper torque though just for giggles ..just don't be Moose Cholock with it and over tighten as I recall think they are only like 12 inch pounds ...
  4. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Jetfixer likes this.
  5. cgutz
    SE South Dakota
    Len,I'm going to need a gasket.....
  6. cgutz
    SE South Dakota
    Tried this didn't work. Looks like new gasket time. Cover has never been off the bike so it is indeed 34 year old gasket.
  7. cgutz
    SE South Dakota
    Is it possible to remove the clutch cover on a XJ550 without draining the oil if I use the side stand?
  8. cgutz
    SE South Dakota
    New clutch cover gasket installed tonight. Old one had small tear/defect at the leaky spot.. Wonder it lasted 34 years.
    Shout out to Chacal for parts and advice.
    So far only a test test ride but no leak.
    Took about 1.5 hours including scraping gasket and oil change.
    Lessons learned:
    1) need razor blade and goo gone to remove old gasket material
    2) mark the bolt locations as they come out as they aren't all the same length :( .
    3) the 2 little posts on the cover gasket area come out...almost lost one in grass and they are used to align cover on engine. :eek:.
    Picture after short test ride:
    Coming next: install new shift shaft seal I also ordered from chacal.
    Stumplifter likes this.
  9. hogfiddles
    Yes....but:
    Yes, you can also do it on the center stand. You'll make a total mess, but it's possible to remove it either way.
    BUT-- if the question i: is it possible to remove the clutch cover without draining the oil AND without losing any of it either, the annswer is still yes, but you can't use the side stand. You'll need to tip it farther to the left side. A sturdy wall and some blankets works well.....done that a couple times.
    (heehee, hey Matti---he said 'butt')
  10. cgutz
    SE South Dakota
    I ended up draining oil. Due for the mid season change anyway.
