Oil Press Switch resistence -- SOLVED
Discussion in 'Other Motorcycles' started by vincentmoy, Jul 21, 2009.
  1. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    Hi all,
    As I posted earlier my oil press. switch is not working. I took it out and tested it with an ohmmeter today and I got about 40 on the R x 1k scale. I'm not sure if it's normal or not.
    Since there's no pressure the contact should be connected (grounded), hance, the ohms should be close to 0 (current can go through, lite up the indicator) .
    Am I right?
  2. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Re: Oil Press Switch resistence
    Sounds right to me.
  3. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    So is it normal with such a high resistance under no pressure? I took a digital multimeter and got a 1670 on a 2000K scale. My gut tells me it's not right.
  4. bill
    bill Active Member
    Raleigh, NC
    Vince I will try and test mine this evening - I need to locate it first ;) have not had to mess with it.
  5. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    Thanks bill, and I'm sorry I have yet to take a pic since I've been pretty busy. I'll try to do it tonight between jobs. 8)
  6. bill
    bill Active Member
    Raleigh, NC
    No problem Ok I found the wire in the headlight and I get just 1 or 2 ohms to ground.
  7. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    Hope it is not too much too ask but I would like to know the reading of the switch itself. It should located behind the cover where the clutch cable goes into.
    It's on the left corner and should onlt have 1 wire connected to a little screw. The whole unit can just unscrew out. It is kinda a big, I'm guessing 24mm. I just used a vice grip to unscrew it (It was pretty stuck).
    I am uploading the photos and I'll PM u when I'm done.
    Thanks for help anyways!
  8. bill
    bill Active Member
    Raleigh, NC
    Ok I can do that tonight - I was taking the cover off anyway tonight to lube up the clutch mechanism.
    But I can tell you if I only get a couple of ohms from the headbucket to ground through that switch it won't be any different.
  9. bill
    bill Active Member
    Raleigh, NC
    Still near Zero - measured the switch...
  10. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    Appreciate it Bill!
  11. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Sorry Vince, i was meaning i think you're right (Bill confirmed it) ~0 ohms when no pressure.
