oil warning light
Discussion in 'Hangout Lounge' started by robbo, Dec 21, 2015.
  1. robbo
    robbo Member
    uk
    oil warning light comes on when starting from cold but goes out when engine is hot.level is ok.
    thats how it works. light is supposed to come on when starting it is a float type device.
    How is the oil level when you look at it in the sight glass, with bike on center stand?
    should be about mid way to all most the top line you want a bubble that way if your gas leaks into the oil you can tell there is a problem because the bubble will be gone.
    when oil is visable in sight glass you can add oil slowley 1 oz at a time to bring it up to the level you like.
    if oil is cold it will be slow to show in sight glass
  3. k-moe
    Sometimes the float gets gummed up with sludge after years of incomplete oil changes. If the light does not extinguish as soon as the engine is started then it may be sticky. An easy fix is to run seafoam in the oil clear out the sludge and free up the float. The harder fix is to pull the exhaust so you can pull the float and clean it directly.
    XJ550H likes this.
  4. Ribo
    Ribo Prefectionist
    ^^^^ what he said -- seafoam in the oil fixed that issue for me. I put it in my gas too. The stuff is so awesome I drink a double-seafoam and coke each night too to clean myself out.
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    robbo, meet Ribo. Ribo, robbo!
    Ribo likes this.
  6. robbo
    robbo Member
    uk
    seafoam not available over here in the uk.will look for an alternative.
  7. mc1oo1
    mc1oo1 Member
    LB,Ca
    Its called Seafoam royal over there.
  8. Ribo
    Ribo Prefectionist
  9. robbo
    robbo Member
    uk
    redex is for petrol only not engine flush.will try wyns engine flush.
  10. k-moe
    If you can get straight Naptha, just use it. The Naptha does most of the work. I'd reccomend using around 10cc of Naptha per 1,000 cc of engine oil since Seafoam is around 3/4 Pale Oil and 1/4 Naptha (with a small amount of Isopropanol and some other stuff that's top secret ( along with oil of wintergreen for the smell)).
  11. George1538
    George1538 New Member
    Port Orchard, WA
    Your information page is blank so I could not tell what type of bike your running but I have found that my 82' XJ650 has a sticky start button that will release from the starter position but stay in just enough to make the oil light stay/come on during running. After blasting a little WD-40 on it the button never stuck again. Hope it's this simple for you, best of luck.
  12. Dave in Ireland
    Ireland
    Easiest source of naptha on the High St is cigarette lighter fuel - at least, it used to be that in tins of Ronson, etc. The downward spiral of the number of smokers has rendered the stuff in shorter supply than it was, and who knows what the EU has dictated as to its use anyway.
  13. MattiThundrrr
    I dunno if youseguyz do much camping out over there, but naphtha is used as a fuel for some types of camp stoves. Coleman brand stoves used it before propane took over.
