Oil wire light
Discussion in 'XJ Technical Chat' started by myasylum, Jul 23, 2014.
  1. myasylum
    myasylum Member
    Grafton, WI
    The light bulb for the oil light has two wires.
    However their is only one B/R oil sending wire.
    Should I splice both bulb wires together and attach to the B/R oil sending wire?
    Can I get the kick stand feature to work without the Atari?
    Thanks!
  2. myasylum
    myasylum Member
    Grafton, WI
    Anyone? ?
  3. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    One is a power wire. The one going to the sensor is a ground seeking wire. Circuit grounds at the sensor through the engine case.
