OK a little help with valve adjustments here.
Discussion in 'XJ Technical Chat' started by streetmaster, Sep 13, 2009.
  1. streetmaster
    streetmaster Member
    So i've got the valve cover removed, and i took the feelers guage that i have with the thinest blade of .005 (.127mm), and i thought i'd see what was going on with my valve train.
    I also used one with .006 (.152mm) and .007 (178mm), I think it was the intake side on #1 and #4 that the .005 (.127) wouldnt fit between the lobe and shim, and the rest were between .006, and .007.
    Does this sound like my valves are a little tight?
  2. TIMEtoRIDE
    Yes, and what feeler gauge set only goes down to 0.005 inch ??
    Buy another set soon, and plan on buying shims from Chacal.
  3. streetmaster
    streetmaster Member
    Yeah i plan to get a better set, just thought i'd take wack at it :idea:
  4. bigfitz52
  5. railtrolley
    railtrolley Member
    Melbourne, Australia
    Another tip is when getting the shims out - stuff a rag into the cam chain tunnel. If a shim should go down the hole, it will be a lot of grief trying to get it out.
