? on making my own pipes
Discussion in 'XJ Modifications' started by blackjack550, Mar 17, 2008.
  1. blackjack550
    blackjack550 Member
    san pedro california
    would that be more cost effective than buying a new set of 4 into 1 pipes and where could i find the right pipe if i did.
  2. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    If you can find a 4-into-1 collector, you'd be in luck. The tubing wouldn't be hard to find to make the rest of the system out of and get it bent, but the collector might be a trick to find.
    You might want to see if an old car header (one from a V-8) would work for a 4-into-1 collector, but I'm not sure of the pipe diameter? PD
  3. mark.deady
    mark.deady Member
    fort bragg
  4. PainterD
    Hey, there ya go. That is an excellent piece to start with. Sealing the 4 pipes into the collector might be a trick, but a wire feed welder might work if the material is thick enough.
  5. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    Call me @ Summit Racing
    We have a ton of stuff to help.
    I'm doing the same thing to my 82 XJ1100!
    330-630-0240
    Ask for Tom
  6. TIMEtoRIDE
    It looks like the 4 pipe "knuckle" will be at least 3 inches around and you will lose alot of ground clearance. Think "speed bump" - - my 4 into 1 is all dented up.
    A flatter collector will still flow well and help clear the filter and drain bolt. 2 into 1 twice. It would be easier to weld from scratch.
    It will sound different if you add a cross-over pipe.
  7. blackjack550
    blackjack550 Member
    thanks for the help fellas im looking into collectors. now trying to get measurements to find the appropriate size and useability. as well as pipe diameter matches.
  8. PainterD
    Blackjack,
    When you get started on your exhaust project, post some photos so we can see what it all involves. Some of us like to make our own "stuff" and it sounds like a fun project! I always thought about fabricating an exhaust system for a bike, but haven't needed to just yet. A tubing bender would have to be involved and I would need to get one of those first. Keep us posted. PD
  9. kevineleven
    kevineleven Member
    Columbus, Ohio
    I'm gonna be making my own, it'll probably be a month before i get started on it though. 4 into 4, straight down one side.
  10. PainterD
    Kevineleven,
    Do you plan to have 4 mufflers too? It would look wild , 4 into 4 would really be different but in a good way.
  11. blackjack550
    blackjack550 Member
    painterd
    well as far as pipe bending goes all you n eed is a torch a metal bench with two pieces of rigid rod tack welded to the table, then you can really get custom on the bends be sure to be patient though so you dont crimp the pipe, but yeah just go wild. im leaving in 3 months to the marines and i dumped my bike yesterday so i dont know when ill start the project now. now i have to fix a broken crankcase cover.
    and 4 into 4 sounds wicked but what are you going to do stack up the mufflers on one another?
  12. PainterD
    You could just use four of those shorty mufflers I have on mine. They wouldn't take up very much room. All four outlets together or two on each side of the bike would look tough.
  13. TIMEtoRIDE
    Kevin runs raw exhaust--he don't need no stinkin' mufflers !
    If you make 'em longer, they'll be a bit quieter, with a lower tone, but the'll still have a wicked rip to 'em.
  14. PainterD
    NO MUFFLERS? I can't see running with nothing on the end of those pipes. That sounds too annoying to me. I guess if you can stand the noise and get by law enforcement, more power to you ....ya really, MORE POWER!!!!
  15. kevineleven
    kevineleven Member
    Columbus, Ohio
    Zero mufflers. I have straight open pipes now, so I'm used to the sound.
  16. blackjack550
    blackjack550 Member
    well in California no mufflers=big ticket so ill stick yo mufflers
  17. schmuckaholic
    California
    Didn't I read somewhere that packing the pipe with sand beforehand helps avoid kinks?
    Oh, and if nobody's told you this already: work on your situps, pushups and pullups before you head off to boot camp. You'll need them... trust me. :wink:
  18. PainterD
    No using the sand idea here. I'll do it right and use a proper pipe bender to get the bends symetrical so they all match. My idea is to use another set of factory headers and go back from there with the same size tubing. I'd make them plenty long and just cut them to length after I get'm all done. I want to go with two pipes on each side of the bike for a more balanced look I think.
    I throw a pair of saddlebags on for longer trips once in awhile, so I'll need the pipes low enough to be out of the way for them.
  19. blackjack550
    blackjack550 Member
    then there not custom they gotta be onehundred percent yours to be completely custom and as far as symmetricality my custom eye is good enough to spot it.
