One ultimate use of XS750!
Discussion in 'XJ Modifications' started by kcoop99, Feb 7, 2010.
  1. kcoop99
    kcoop99 Member
    BFE, Nebraska
  2. Hillsy
    Hillsy Member
    Was that supposed to be a link?
  3. markie
    markie Member
    Suffolk, England
    Perhaps I am missing the Stateside humor? Doesn't look like an XS 750 triple to me.
  4. rpgoerlich
    rpgoerlich Member
    Katy, Tx
  5. TIMEtoRIDE
    Hey look- - a single carb into 3 CYL- - I wonder what tuning issues he has??
  6. kcoop99
    kcoop99 Member
    BFE, Nebraska
    Ooops...sorry! That was supposed to be a link! Just looked like a little fun to me.
  7. TIMEtoRIDE
    I just had to ask the guy about the intake set-up, and he said. . .
    All I did was go up a size in carbs. The stock carbs were 34mm Mikuni, I went up to a 38mm with the stock jets. I also built a plenum type manifold running an 1 3/4" center section with the others tubes being 1 3/8". It's works pretty well...no hesitation, no starving that I've noticed. If you set your 4 cyl. up with a plenum type manifold you should have no problems. I know of a few set up that way already. Just remember, the carb is still only feeding one cylinder at a time.
    Paul
    Food for thought for those interested in a one carb set-up.
  8. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    It does make sense. Cars have single carbs for years before fuel injection. I'd be interested in playing with the idea myself. I'm not all that bent on performance persay, just so it runs right.
  9. Creamsoda
    Creamsoda Member
    That's the ugliest thing I have ever seen.
  10. seaguy
    seaguy Member
    Coastal,AL
    Trikers are a special breed indeed.
  11. Polock
    how about a side CAR
  12. dwcopple
    dwcopple Active Member
    bay city, michigan
    been done several times...mine is here
  13. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    2 part question dw :)
    1, what carb did you use?
    2, What would you charge for a manifold?
    Wouldn't mind trying this, was having a few issues with my carbs just before I put her up for the winter, one side has some degradation of the aluminum inside... cleaning them up now...
