Opinions on fork seals
Discussion in 'XJ Technical Chat' started by Neil Abbott, Jun 20, 2017.
  1. Neil Abbott
    Neil Abbott New Member
    Shepherdsville, ky
    Looking for some input on the All Balls fork seal/dust wiper kit as opposed to OEM seals. Anyone use the All Balls kit before? Are OEM seals worth about triple the price?
    The All Balls set is good. I've used them on four bikes; no leaks.
    Stay far, far away from Leak Proof brand. The name is quite ironic.
    geg81 likes this.
  3. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    I have used all balls on dozens of machines. I can't think of a problem. Though their dust boots aren't as attractive as oem. In my opinion
  4. Neil Abbott
    Shepherdsville, ky
    From the images on there catalog it appears that the spring on the seal is exposed, is that the case?
  5. k-moe
    Yes. Same as OEM.
  6. CanuckXJ
    CanuckXJ New Member
    Manitoba
    I just put All Balls fork seals/dust boots on my 80 XJ650. Can verify that the dust seal spring is on the outside.
  7. Jetfixer
    Just did my forks with All Balls Seals ,yes spring is on outside of dust seal. I like these seals and NO more leaks!!!!
  8. drmmrby2k4
    drmmrby2k4 New Member
    Janesville, WI
    I just put a set of seals and dust boot on my 82 650 and they look just fine. Have a leak, fix a leak. Unless you are pure oem, save a little money and trust the reviews on all balls.
