Orange n Black's 700
Discussion in 'XJ Modifications' started by Orange-n-Black, Jul 17, 2010.
  1. Orange-n-Black
    Memphis Area
    Well I've almost finished the mods, so here's a few pics.
  2. Orange-n-Black
    Memphis Area
    Here's a pic of my bars, upside down Clubman's with new mirrors,grips,speedo and clutch/brake levers.
      File size:
      63.9 KB
      14,385
  3. Orange-n-Black
    Memphis Area
    I installed the speedo in the center of the bars and ran the cable through the ignition channel, so relocating the ignition was a must.
  4. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    Can you get a closer pic of the speedo?? I may have to reposition my ignition as well. Did you use 1/2 of a bar clamp to put it where you did? lookin' good...
  5. deadohiosky
    deadohiosky Member
    Columbus, OH
    Lookin' good, like those bars.
  6. Orange-n-Black
    Memphis Area
    Thank's guys, I used the clamp that came with the speedo (JC Whitney),I 'll take a closer pic for you.
  7. Orange-n-Black
    Memphis Area
    Here is the clamp pics.
  8. Orange-n-Black
    Memphis Area
    I didn't like the rear fender and tail light,so this is what I did.
  9. Orange-n-Black
    Memphis Area
    Another pic of the ignition in relevance to the tank and the new paint.
  10. Orange-n-Black
    Memphis Area
    Some pics of the forward cotrols. I made a braket that bolts to the upper engine mount and replaced the bolts with new grade 8 bolts. Then drilled holes to mount the original pegs and built the controls around them. They're not pretty but functional, besides after a coat of black you won't be able to tell anyway.LOL
  11. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Thats lookin like a pretty cool build! Diggin the tony the tiger lol
    I wish I had access to tools like you do. I could do some damage on a bike with a welder and some sheet metal and a bender.
    Lookin good dude
    -Chris
  12. Orange-n-Black
    Memphis Area
    Thank's SLKid I was going for black fast flames but it did turn out to look like a tiger.I had purple pin stripe tape around the flames but it all peeled off in the heat, I was very heated too at that point.
  13. Orange-n-Black
    Memphis Area
    Here's a pick of the front fender and the tank.
  14. Mad_Bohemian
    Ravenna MI
    I'm diggin' the Tony-the-Tiger stripes! Pretty cool!! :D
  15. Orange-n-Black
    Memphis Area
    Thank's, I'll post some pics of the pvc intake later.
  16. streetmaster
    streetmaster Member
    WOW nice pic of the Clubmans, try'in to get some pics of those type of bars put on that way a few weeks ago because im planning on a set of them my self, looks pretty cool.
  17. Orange-n-Black
    Memphis Area
    I got the clubmans from JC Whitney for 22.50, just couldn't turn them down and I didn't have to change any of the cables or brake lines.
  18. frankenbiker
    frankenbiker Member
    gobles michigan
    I used the exact same bars on my bike, they rock, I'm looking to do a solo speedo also, but most are for 1"-1/2" bars, guess I'll look at my whitney catalog again.
  19. Orange-n-Black
    Memphis Area
    Hello Frankenbiker, look online, I believe it was 40.00 and they also have a matching Tach.
  20. Orange-n-Black
    Memphis Area
    I got the tail light from J&P Cycles, it's for a Harley Fat Bob. I just welded a couple of bolts on the inside of the fender and sloted the mounting holes on the bracket and it fit great.
