ordered wrong brushes?
Discussion in 'XJ Technical Chat' started by ink251, Oct 1, 2007.
  1. ink251
    ink251 Member
    Auburn, AL
    I ordered 2 sets of brushes for my xj550 alternator from z1enterprises.com. I tried to install them and realized that they are too small and wont fit anywhere. The website said they were made for xj550's. Whats up?
    Heres the link: http://www.z1enterprises.com/detail.aspx?ID=2673
    Am I overlooking something obvious?
  2. Jackncoke
    Jackncoke Member
    Alton, Illinois
    Can you take a pic of where you tried to install them at for some of the more experienced fellows here? If you are sure that you had the right spot and everything, then not sure.... I will try to find out more on it.
  3. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    I found some drill motor brushes at ACE, they werent the right size but I used some sand paper to size it for diamater and length.
    Works good as the factory brushes.
  4. PghXJ
    PghXJ Member
    Pittsburgh PA
    that's odd, I ordered those same brushes not long ago and they fit just fine.
  5. chacal
    They should fit like a champ. All the XJ-series bike should use the same brushes/holders.
  6. PghXJ
    PghXJ Member
    Pittsburgh PA
    only thing I noticed with them is they are exactly the same length as the ones I took out...so now I have a spare set. I just replaced them because of age considerations. I had no clue if they were originals or not.
    They should work. Can you post a picture of them?
  7. chacal
    The replacement brushes are about 1mm shorter than the originals, and do not have a "wear line" scribed into them (which you can do for yourself---gently---before install if you find that useful). Other than those minor issues, they fit and work like a champ!
  8. PghXJ
    PghXJ Member
    Pittsburgh PA
    yeah, my stock ones have the line scribed in them and it is about 5mm from the end...approximately.
    The new ones were the same length, so I am guessing I only had 1mm of wear on them.
  9. ink251
    ink251 Member
    Auburn, AL
    I decided not to open the starter back up so the brushes are up for grabs. If you want a set of them PM me. thanks for the help, peace.
  10. PghXJ
    PghXJ Member
    Pittsburgh PA
    wait...do you mean alternator? The brushes you ordered are for the alternator, not the starter...totally different animal.
  11. chacal
    The starter brushes ARE different between the 550 motors and all others....550's are all by their lonesomes as far as fit and size is concerned. However, the items linked to in the original post ARE alternator brushes.
