oring in carbs
Discussion in 'XJ Technical Chat' started by brent_bastien, Apr 11, 2008.
  1. brent_bastien
    brent_bastien Member
    Commerce mi
    i have an 81 650 and i need to replace one of the orings under the fuel mixture screws anybody know where i can get one
  2. chacal
    Hey Brent, I carry the o-rings and LOTS more!:
    http://www.xjbikes.com/Forums/viewtopic ... t=180.html
    Idle Mixture Screw Parts:
    NOTE: idle mixture screws are also referred to as "pilot mixture screws" or "pilot screws".
    ddd) Aftermarket Hitachi Idle Mixture Screw O-Ring.....a "must-replace" item when rebuilding your carbs. Made of long-lasting, fuel-resistant Buna-N material.
    HCP895 Aftermarket Hitachi idle mixture screw O-ring, each:
    $ 1.00
    HCP895SET4 Aftermarket Hitachi idle mixture screw O-rings, set of 4:
    $ 3.00
    eee) Aftermarket Hitachi Idle Mixture Screw o-Ring WASHER.....also a "must-replace" item when rebuilding your carbs. Made of long-lasting, fuel- and water-resistant 18-8 stainless steel material.
    HCP896 Aftermarket Hitachi idle mixture screw o-ring Washer, each:
    $ 1.50
    HCP896SET4 Aftermarket Hitachi idle mixture screw o-ring Washers, set of 4:
    $ 5.00
    ims6) Aftermarket carb idle mixture screw TENSION SPRING, brand new reproductions exactly replace damaged, rusted, or missing originals. High-strength carbon-steel coil springs have a baked yellow-zinc plating as original.
    HCP6573 Aftermarket reproduction idle mixture screw Tension Spring, fits all Hitachi HSC32 and HSC33 model carbs as used on all XJ650 (except Turbo), XJ700 non-X, and all XJ750 models, each:
    $ 3.50
    HCP6573SET4 Aftermarket reproduction idle mixture screw Tension Spring, fits all Hitachi HSC32 and HSC33 model carbs as used on all XJ650 (except Turbo), XJ700 non-X, and all XJ750 models, set of 4:
    $ 10.95
  3. RPCVFR
    RPCVFR Member
    Sioux Falls, SD
  4. crewwolfy
    crewwolfy Member
    Chicago, IL, USA
    I picked up a set of o-rings and washers for the fuel mixture screw from Chacal last week. A lot less than $60, probably under $15 for the set. If you don't need to bowl gaskets, I'd go that way.
